Question about Coby TF-DVD7060 Portable DVD Player
Need a decrypt code?
I recently brought 2 coby TF-dvd7060 portable dvd players on line and can only play region 1 dvds i am in region 4 (australia), is there a code to unlock my players?
  • camposcr Dec 18, 2007
    I need to unlock the COBY TF-DVD7060 for all regions.
    Thanx
I used the following steps.
In Remote Control:
1) Press SETUP
2) Press Fwd (»)
3) Press Rwd («)
4) Press Fast Forward (»|)
5) Press Fast Rewind (|«)
Original region number (1 to 6) will appear - uses arrow keys (Navegation) to change to 255 (ALL Regions).
A couple notes:
- The keys referred to in the above hack are on the remote control (not on the front panel). But, if you want, you can use the front panel to implement the hack – just use the key equivalents (i.e., for SETUP, press Mode twice; for », press and hold »| for 2 seconds, and so on ).
- When the Region Number appears, it is in the upper right corner of the Set Up window without any label. In other words, if your player is currently set up for Region 1, look for the number 1 to appear in the upper-right corner of the Set Up screen (once you've pressed the correct sequence of fast forward and reverse keys). Then use the arrow keys to toggle the number to 255.
If you remove the main battery, you might have to do the trick again.
Enjoy.
Posted on May 04, 2009
You can use the same as that for the 7050 model. You NEED to use the remote control, press setup and then ffwd, frwd, fwd, rwd in sequence, it will appear a number. Press the right arrow key until it reaches 255 (it is fast, it jumps from 001 to 255), to get out, press set up again. You know can read all regions. In fact this is the same fix for the 7050 model.
Posted on Jun 01, 2008
My son brought a disk over the Internet he is unable to play it
http://en.wikipedia.org/wiki/DVD_region_code
for DVDs you are in region 4, america is in region 1
the only other region that it would play from is south america
so it will not work untill you find a dvd player that plays DVDs from all regions
i would try and get your money back from the company and say it doesnt work (act dumb) dont go saying its wrong region. just say it doesnt work
and if you want to watch the DVD buy it from austrailia
May 10, 2010 | Electronics - Others
Won't play Region 2 PAL dvds
Here is the code..
1. Power on
2. Tray open
3. Push MENU
4. Push 8888
5. Push Display
6. Push in desired region 0-6, (0 is ALL REGION )
7. POWER OFF
8. REGIONFREE!!
Jay
May 20, 2009 | Coby DVD-257
Need to unlock tf-dvd7008
Step 1- open the DVD tray
Step 2- Press the "MENU" button on the remote control
Step 3- Press" 8888"
Step 4- Press the " DISPLAY" button
Step 5- Select your region. I would suggest enter " 0", this will make it a all region player.
Step 6- Press the " SETUP button to exit.
Mar 31, 2009 | Coby TF-DVD7006
Problems playing DVDs due to regional codes.
FIRST
CONFIGURE YOUR PLAYER IN THE LANGUAGE YOU WANT TO LISTEN, AND THE SUBTITLES YOUR GOING TO USE BECAUSE ONCE YOUR DISC IS BEEN REPRODUCED NONE MENU IS GOING TO WORK.
SECOND.-
PUT YOUR DISC ON YOUR REGION YOUR GOIG TO USE AND, SET ON YOUR REGION AND INMEDIATLY AFTER TO CLOSE THE COMPARTIMENT START TO PUSH CONSTANTLY, (TOO MANY TIMES), THE NUMBER "6" - ENTER
YOU HAVE YO PUSH IT 10 TO 15 TIMES , AND THEN YOU CAN SEE THE MOVIE WITH THE LANGUAJE AND SUTIBLES THAT YOU HAVE SELECTED BEFORE.
ENJOY YOUR MOVIE.
MAYBE FLIP UP A MESAGE LIKE " REGION INCORRETA" "WRONG REGIION", DONT WORRY, YOUR VIDEO IS GOING TO REPRODUCE HOWEVER.
IF 6 - ENTER DOESNT WORK, TRY WITH 7 - ENTER A LOT OF TIMES (I MEAN CLICKING) OR 8 OR 9 OR 10, IT DEPENDS OF THE NUMBER OF CHAPTER THE MOVIE STARTS.
ONCE YOU OFF YOUT REPRODUCTOR IT RESTARTED LIKE YOU NEVER DID THIS PROCEDE.
YOU HAVE TO DO THIS IN EACH MOVIE YOU WANT TO PLAY.
or1. Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Dec 03, 2008 | Sony DVP-FX810 Portable DVD Player
Unlock region codes for portable dvd player - panasonic DVD LS80
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Aug 04, 2008 | Car Audio & Video
Unlocking code
With no disc in player:
On remote control:
Press Setup
Press >>
Press <<
Press >>I
Press I<<
(Current region shown on screen)
Push right arrow to increment 2.. 7.. 255
(When number = 255, Press Enter)
Press Setup to finish
Jun 16, 2008 | Coby TF-DVD7005 Portable DVD Player
Programmed for region 2....Need to change to 1
Q: What is Regional Coding enhancement(RCE)?
A: It's a digital enhancement added to some Warner Bros and Columbia DVDs to stop region 1 (R1) DVDs from playing on Region-free DVD players.
Q: What's the difference between Region Coding and RCE?
A: Regional Coding enhancement(RCE) is an additional layer of protection which some studios have placed on select REGION 1 DVDs to prevent them from playing on region-free or multi-region players. Region Coding is a part of the DVD spec which divides the world into 8 regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Basically, DVDs released in each region will typically only play on players sold in that region. IE a DVD released in the UK *Region 2* would not play on a player sold in the us *Region 1*. You can tell what Region a DVD is coded for by looking at the back of the box for a Globe with a number on it. The number correlates to the region list above. If a DVD is listed as 'Region 0' it means that it isn't coded for any region and should play on ALL regions players.
Dec 14, 2007 | Philips 30DV693R 30 in. TV/DVD Combo
COBY TF-DVD7060 SAYING WRONG DISC
In Remote Control:
1) Press SETUP
2) Press Fwd (»)
3) Press Rwd («)
A couple notes:
Enjoy.
Sep 05, 2007 | Coby TF-DVD7060 Portable DVD Player
Region
coby 514.
power up. put disc in tray
press set up
then vol+ vol- vol+ vol-
code appears in top right 1
change altering left and right buttons
leave on 255 multi region (all discs)
press set up.
Coby DVD-514M
Turn unit on with remote
NO DVD in the tray (mine was closed, but opened might work)
Press TITLE then 1 then 9
Gray box will appear in the center of the screen with number 1 in the middle
Using up/down arrows change to desired region (0 for REGION FREE)
Jun 12, 2007 | Coby DVD-514 DVD Player
Coby TF-DVD7060 Portable DVD Player Logo
145 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
