Question about Palm Treo Pro Smartphone
I have a Palm Pro and as of yesterday it is not syncing my contacts - it is checked to sync and it is syncing everything else - but not the contacts. I use Outlook / Vista - any ideas?
ERROR: 00001013 - calander sync.Options When I sync my palm the date book is not synced (it used to but stopped). All other data is transffered well. It is Palm m515, Windows XP Pro ERROR:...
You can use third-party synchronization software (IntelliSync, iSync, Missing Sync, etc.), contact the third-party developer for assistance.
Good luck.
Feb 05, 2011 | Palm m515 Handheld
Palm treo keeps turning off
this is caused by a software conflict do you sync you device? if so it can be something your syncing over to the phone from your computer you want to sync over just your contacts then tasks, and media items. if you do not sync you device then i would suggest backing it up and doing a hard reset on it because the powercyling is due to a software failure
Apr 02, 2010 | Palm Treo Pro Smartphone
Suddenly when I try to sync the Treo with the MAc(OS10.6.2) I get the following message: The application "HotSync Manager" could not be launched because of a shared library error: "" I had been...
You will most likely have to reinstall Palm Desktop because either a Shared Library is always in use or it's missing. A reinstall should help.
Feb 05, 2010 | Palm Treo 755p Smartphone
Sync. gets frozen when reaching the "media" part.
CHECK YOUR TREO SYNC SETTINGS.RICHARDM69(WRITE PROTECTED?)
Dec 23, 2008 | Palm Treo 755p Smartphone
Syncing Palm Centro to Palm Software
Export your contacts out of Palm as a CV file then import them back into LotusNotes
Nov 13, 2008 | Palm Treo 500 Centro
Hotsyncing Z22 device with Palm Desktop
Check what is the action set to address book (contacts) conduit in the HotSync manager in System tray, make sure that it is set to "Synchronize the files" or you can change it to "desktop overwrite handheld" then perform a Sync.
Oct 23, 2008 | Palm Z22 Handheld
Contacts will not sync
I had this exact same problem did everything U discribe. I even change cables stood in the wind facing north and sacrificed a small animal (hahaha) I called Palm, they said do ahard reset. (haha) reinter 24 day of data manually into the desktop, I dont think so. Then I shut down all the conduits but calender. then I set the conduit to have the handheld over-write the desktop. PROBLEM solved!! No data loss No hard reset No re-entering data. I then folowed up with several test syncs in several conduit configs, including test data in both desktop and handheld. hope this helps.
Sep 05, 2006 | Palm Treo 650 Handheld
Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have trusted...by mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Sep 12, 2005 | Palm Tungsten E Handheld
Cannot sync outlook calendar
1) Only one username to use. 2) Not sure about this one. It was working fine exactly as I have it setup now. The only thing that changed is I reinstalled the software, did a hard reset and setup a profile.
Sep 11, 2005 | Palm IIIc Handheld
Palm Treo Pro Smartphone Logo
64 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
