Question about Sony Ericsson W850i Cellular Phone
Camera not working
I hav a w580i scince 5 months now... and now when i try to strat its camera it says "another application is running. close it and then start the camera"
there are no running applications.... i tried to resatr it... no go... plesae help!
When i try to use the camera, getting an message stating another application is running, please close the application then try again. No other application is running. Sony Ericsson W580I
this could be one of 2 things either the main camera(2MP) or the vga(video call) is faulty. you need to test the vga camera by going onto the video call mode. if that works then its the 2mp camera.
hope this helps...
any further questions I'll be happy to help.
g
Oct 25, 2009 | Sony Ericsson W850i Cellular Phone
Another application is running plz close all other application &
shut down the phone and do a soft reset by pulling the battery from phone wait 30 sec place battery back in phone and reboot this will set the phone back to the factory settings. if it still doesn't work you may have a software problem check to see what auto functions your phone has and make sure you have shut any non essential functions off this should solve your problem. if not your phone will need to be reset by your provider or phone manufacturer.
Jul 19, 2009 | Sony Ericsson w580i Cellular Phone
It showing message while i open the camera"Another application is running.close it and then start the camera".
yea i have this phone it usually only does that if you are talking but some spplications and the camera cant run at the same time like when your listening to music.. it stops when picture is taken so ya...
May 31, 2009 | Sony Ericsson w580i Cellular Phone
W580i camera problem
Solution:1(model:W580i)
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Solution:3
Throughout all the mails regarding that error messages using Googles Search
Don't go Mobile service stations without knowing a nature error, because they ready to cheating us. Becareful.......... Freinds
Feb 15, 2009 | Sony Ericsson w580i Cellular Phone
Camera problem it says ''another application is running
Hello. Please close all the application that are using the cam. Restart the computer, then launch the application. This will solve the problem if not uninstall and reinstall the camera drivers, for the drivers either refer to the CD which came along to you or go to the camera manufacturer website ( ex:- HP.com etc) and download and instal.
"Another application is running. Close it, then open the camera."
If any problem first check by software.Bcoz more problem salve by software.
Jan 28, 2009 | Sony Ericsson w580i Cellular Phone
SONY ERICSSON W580I DISPLAY PROBLEM.....
More than likely you will need to reseat the lcd connector.
Worst case is you need to replace the lcd screen.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Jan 07, 2009 | Sony Ericsson w580i Cellular Phone
W580i camera won't work b/c other application is running
the software has sum bug in it ,.... get it upgraded that is the best solution to it
Dec 07, 2008 | Sony Ericsson w580i Cellular Phone
Camera problem with W580i
The firmware on the phone need to be reflash to correct this problem you can do this online at topsony.com or take it to a mobile service center close to you to have this done.
Jun 01, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Sony Ericsson W850i Cellular Phone Logo
95 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
