I can not surf the net
I have installed my new wireless router but I can not eccess the network ?
  • Ryan  Ruch
    Ryan Ruch May 11, 2010
    Did you use a wizard to install the network with? If so what security settings did you use? WEP, etc
  • 329 Answers
Try to disable firewall......if it doesn't work then plz let me know about the wireless router make and cabling of internet.......
Posted on Sep 30, 2009
Belkin N300 router, renamed network, having many issues with my 4 yr old Dell 1520 connecting to the net, network often say 'unidentified network'. takes lots of fiddling to connect. however,...
The best solution is to delete your network and create a new one
Also reset your Belkin Router to factory default settings.
This would take care of your issue.
If you need suitable assistance you can also get online technical support. I would suggest you to contact TheBestPcDoctor. I get my issues fixed by them.If you need you may also contact them @
www.thebestpcdoctor.com or via 877-407-9229
Oct 05, 2011 | Belkin Surf N300 Wireless N Router
I need my WEP key code for my wireless router DSL - 2640R Broadland Wireless G ADSL2+ Router. I need WEP key...
So access the computer that the router is installed on. Open the program that managed the network ( I have seen these both as a program installed on the computer and as an Internet accessed destination). Select add device, once you have done that the key that you need should pop up. Just put that in your laptop and you should be ready to surf the net. If this helped please rate Thanks Robert
Jul 02, 2011 | Computers & Internet
Can't connect wii after installation of new wireless modem
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Apr 04, 2011 | Belkin Wireless Surf Router (F7D2301)
I am changing to a new PC, from one that is already connected to a ASDL+ modem and a Linksys router. Do I need to install new drivers(for ASDL+ modem or Linksys router) in the new PC? Or can I just plug...
For you to use the modem direct - you may need drivers - BUT connecting to a router does not require any drivers - and you should just be able to plug in and go If wireless - then you may need to provide the wireless security key if the wireless is secure - and if the wireless is on the same SSID name as before that may cayse a problem - but you can renove the xp wireless profiles to overcome that Wireless Profiles
  • http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • http://www.tp-link.com/support/showfaq.asp?id=186
- delete the preferred networks start>control panel>network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button you will then have to enter the wireless security key for any networks you connect to
If on a LAN connection - you may need to turn off the modem/router and PC - then turn on the modem - allow to settle and all the light to show normal status - turn on router and do the same then turn on the PC
Apr 13, 2010 | Linksys Wireless-G Broadband Router
Can't acess laptop computer but can see on desktop
To allow access between both the laptop and desktop the hard drives or folders on both computers must be made shareable.
Right click on the C drive or folders or other hard drive then click on Sharing and Security - Sharing. Then in Network Sharing and security - tick Share this folder on the network and enter a share name that identifies this computer and drive/folder.
Apr 05, 2010 | Linksys Wireless-N WRT150N Router
Have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Jun 28, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless network not connected
most wireless routers have an option of "do not broadcast ssid"
(you have to already know the name of the router)
so you need to login it to your router and check all the options and mak
let us know how it works out andask if you need help with anything else
May 20, 2009 | Toshiba Satellite 5105-S501 Notebook
NEW WINDOWS VISTA NOW LINKSYS WILL NOT INSTALL
first coonect your wifi router witjh your laptop with ether net then go to this link
http://192.168.0.1
then type user :admin and password also admin or blank
then go to dhcp then enbale it with auto .
then disconnect your cable from laptop.
then go to my network places then find wireless network then simply conect your network.
thtas it.
then check tcp/ip poperteis in your lmy network places properties enable in auto get ip adreeses.
Nov 04, 2008 | Linksys Wireless-G Broadband Router
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Jul 07, 2008 | Linksys Wireless-G WPS54G Print Server
Wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Jul 05, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
David Payne
David Payne
