Question about Nokia 5200 Cellular Phone
When i press menu button the phone just get hang up
2 Suggested Answers
lexzy80
  • 943 Answers
SOURCE: when i press MENU button
There are many known issues with this phone and other closely related models. These problems range from the above mentioned to completely crashing of the phone's system.
You are currently experiencing one of the most complicated problems that this phone is known to give.
It normally arises as a result of filled up memory or little remainder of the memory. In some cases, when the memory card inserted is usually of a big capacity, it can also cause the phone to have a slow response and equally make it seem to hang.
The easiest ways you can go about this is by removing the memory card and see if it does the same thing again.
If it doesn't repeat it, then you can conclude that the memory card is either full or causing it to hang. On the other hand, if it still repeats the same thing, give it some time(about 5-7minutes) and see if it opens the menu. if it doesn't then you could be experiencing a software failure and it is advised that you see a repairer to help you diagnose the phone for any errors.
Hope this was helpful?
Posted on Feb 05, 2011
How might I fix or remove freezing/hanging issue with both factory installed and playstore apps and wigets on an unlocked motorola mb855 running android 2.5 without use of a computer and free?
here
You can try to restore the Motorola Photon 4G MB855 like this:
  1. Enter into your phone settings by pressing the Menu button.
  2. Choose Settings and then select Privacy.
  3. Now select Factory Data Reset and then choose Erase Internal Storage.
  4. Lastly, select Reset Phone.
motorola-photon-4g-mb855-hard-reset-300x279.jpgFor those that are unable to use the Android system, mainly because the phone refuses to boot normally, you can try to restore the MB855 using the recovery menu. Here's how it's done:
  1. Turn off your phone and then press and hold the Volume Down Button.
  2. While holding the Volume Down button pressed, tap on the Power Button and the Fastboot menu of the Android system should appear on the screen. This is the point where you should release all buttons.
  3. Use the Volume Down key to navigate through options and when you see "Android Recovery", chose it by pressing the Volume Up button.
  4. Once the triangle sign appears, press both the Volume Up and Down keys, at the same time.
  5. In the newly appeared menu, navigate using the Volume buttons to Wipe Data / Factory Reset, and select this option by pressing on Power.
  6. Confirm your option by selecting Yes, once again with the Power button.
  7. Wait for the process to complete and reboot the phone.
gooluck...
Jun 21, 2014 | Cell Phones
Tip
Siemens MODELS CODES & DESCRIPTIONS
*#0003*(secret code 8 digits)# All Siemens Phones: Service Provider Unlock
Siemens S25/C25
SP unlock *#0003*(secret code 8 digits)#
Show IMEI code: * # 06 #
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Siemens S1/S3/S3 Com
To view the software date and else with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey.
To view some other stuff with S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey twice.
To view the software date with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM installed menu 98 and left softkey twice.
ACTIVATE MONITOR MODE
Siemens S1/S3
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Now "Monitor" should appear at the bottom of the Network Options menu.
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Menu 10 Engineering,
Menu 10.1 MS info,
Menu 10.2 software detail,
Menu 10.2.1 software version,
Menu 10.2.2 EEPROM version,
Menu 10.3 Test/production details
Menu 10.3.1 Hardware deta
Menu 10.3.2 production deta
Menu 10.3.3 Service deta
Menu 10.3.4 Mechanical deta
Menu 10.1.1 MS info on, then on the screen show these, for example:
FCN RXL C1 C2
642 011+11+91 -> PAGE 1
CID DSC CB
11211 045 000 -> PAGE 2
BCC NCC TN
000 002 00 -> PAGE 3
RXf RXs RQf RQs
00 00 00 00 -> PAGE 4
ATa APa Hn Hf
001 000 05 00 -> PAGE 5
DTU DTD HP CI
+ ? - - -> PAGE 6
MM CC RR
IdNS Nul Idl -> PAGE 7
on Aug 30, 2009 | Nokia 9500 Communicator
HOW TO UNLOCK A PANTECH PHONE WITH TO MANY PATTERN ATTEMS
1. try entering null as password. (together with your google username) 2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock 5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. go to recovery (vol down + search +power) and do a factory reset/wipe (it will erase all your files)
Feb 18, 2014 | Pantech Great At&t P9070 Burst Smartphone
HOW TO FORMAT HANG LG-C660R
My Dear:
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Format it
Dec 01, 2012 | LG Optimus Pro C660 Android Smart Phone...
How can I hang up?
okay heres how you do it..
Slide your finger from the very top going down
the wifi, bluetooth, gps ,sound and auto rotation screen will be open
on this page you will see that your call is still active
just press clear and you will hang up the call
after this just press the home button on your phone and your back to the main menu
Jan 17, 2012 | Samsung Galaxy S GTI9000 Smartphone
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
H,i I tried to give a hard reset my phone but pressing the key recovery and has a symbol on the screen, now does not respond, how long should I wait or should it be immediately?
Did you press the MENU.
Follow the following steps:
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone.
Mar 17, 2011 | HTC Hero Smartphone
My nokia 3230 having hanging problem..wat is da problem
Might a chance of virus infaction. Please scan your mobile by updated mobile anti-virus. If not done then i suggest you please format the phone & install the updated version. Thanks.
Mar 02, 2010 | Nokia 3230 Cellular Phone
Hanging
software problem..contact service techn
Jun 30, 2009 | Nokia 3120 Cellular Phone
Parrot memory full
I had same problem too.
I have googled 3 days and found the solution from MULTICAN manual.
•Reset the hands-free kit:
Repeat the following sequence five times:
press the "Volume (-)" button and then the "Volume (+)".
And also F.Y.I.
•Enter the menu:
Press the following sequence twice: [SEEK up] button then the [SEEK down] button.
•Go forward through the menu: Press the "Volume (+)" button.
•Go backwards through the menu: Press the "Volume (-)" button.
•Select a menu option: Press the "Phone" button.
•Cancel a function: Long press of the "Phone" button.
Jan 18, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Nokia 5200 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
