Question about Delta 2 Handle Widespread Lavatory With Metal Pop Up C Spout-L/ Handle s
Drain doesn't work . If I twist drain water will drain
  • 67 Answers
Theres a pop up assembly under the sink. The little clip on the rod may need adjustment to make the popper come up more or, theres hair ect clogging it just put in some Drain cleaner.
Posted on Sep 24, 2009
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Daniel
Aug 27, 2011 | Dishwashers
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
E04 Mashine does't drain
Hi, E04 means that you are not draining quick enough, if you are using HE detergant then your drain line is probably clogged. There is a round access panel on the lower right corner of your washer. If you stick a small screwdriver through the tiny little hole on this panel and twist the panel off you will see the drain pump catch. You can twist this cap off by hand and remove all the debris inside. WATCH OUT a lot of water will be coming through.
Jun 25, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My model wdc1025 will not drain wash water or rinse water
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance. Hope this helps...
Daniel
Sep 02, 2010 | Splendide Washing Machines
Water entering twist mechanism which closes K-7160 tub drain and dripping on outside of Kohler cast iron tub into basement below. Is the solution to tighten gasket on outside of tub or fix water backsplash...
If the water is entering through the overflow on the twist mech. then the gasket should be tightened and or adjusted. If possible feel around on the top of that fitting from the back side to rule out water leaking from other source, such as backsplash or faucet from escutcheons. It sounds like you have a pretty good idea of how to fix it. I hope this helps.
May 20, 2010 | Kohler CLEARFLO BATH DRAIN K-7160-TF-BV
DRAIN
I take it that you removed the drain trip linkage and stopper through the vent hole .
You must now run a small hand or small power snake the less than eight feet to open the drain.
You can also plug up the vent,tightly and  try a flat plunger on the tub drain .
Apr 20, 2009 | American Standard 1583.470 Universal...
Plumb Pak Corporation Twist & Lock sink drain will not drain
The small disk right under the strainer is adjustable and has a lock nut. You will need to try and adjust this. If it doesn't work, the I would sugest replaceing them. They aren't that expensive plus they are easy to replace. Good luck!
Apr 09, 2009 | Plumbing
Delta 2 Handle Widespread Lavatory With Metal Pop Up C Spout-L/ Handle s Logo
55 people viewed this question
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
