Question about Panasonic SA-HE7 Receiver
Can I adjust the level of each channel from the receiver, not from the remote control (the level button on mine is not working)?
    Scholar:
  • 131 Answers
Depends on the reciever, some due and don't, my advice is to get a universal remote that will work with your reciever and then you can adjust your settings no problem. I own a Yamaha RX-V3800n and you can hardly do anything without the remote.
Hope this helps
Posted on Sep 24, 2009
Froze
To see if the problem is with your remote control, go to the receiver and use the channel up/down buttons on the receiver itself. If you can change your channels with the buttons on the receiver, the batteries in your remote control probably need to be changed.
If you can't change channels from the receiver, turn off the receiver. Then unplug it for at least 15 seconds. Plug the receiver back it and turn it on. Again, try changing channels from the receiver itself.
Tune to a channel, and while programming is playing, try tuning to the missing channel by entering the channel number on the remote control keypad to see if channels change. Do not try to select the channel from a channel list, program guide, or favorites list.
If this approach takes you to the correct channel, you need to adjust your favorites list function. Press the "guide" button on your remote. Look for a button on your remote called "fav" or "list." Press it several times and watch for an indication at the top of the guide that you are moving from "all channels" to a particular favorites list.
If you are locked on one channel only, your Channel Lock feature is likely active. Consult your owner's manual to unlock the rest of your channels. See your owner's manual for information on managing favorite channel lists and locking out channels. Enter your password, if necessary.
Jul 30, 2012 | Coby TFTV1925 19 in. LCD TV
Channel lock is stuck on
May 28, 2011 | Televison & Video
Hello how doi adjust the left and right balance for the left and right channel level
The only 'balance' is to adjust the channels relative to each other with the test tones.
http://www.retrevo.com/support/Pioneer-VSX-24TX-Receivers-manual/id/386ag014/t/2/
Page 29.
The "Effect/Channel Select" button on the Remote (left of the Menu button), will let you change the level to any channels while listening to a program. Page 22
"EFFECT/CH SEL +/- buttons (See p.38)
EFFECT : Use these buttons to increase or decrease
the amount of effect applied in a DSP or Advanced
Theater mode. When the amount of effect is
increased in a DSP/Advanced Theater mode the
characteristics of that mode become stronger and
more noticeable. The scale ranges from 10-90 with 70
as the default setting. First turn on the DSP/
Advanced Theater you want (by pressing the DSP/
Advanced Theater button until you get the mode) and
then increase or decrease the amount of effect.
CH SEL : You may want to adjust the channels when
listening to some sound sources. Use this button to
select the channel you want to adjust.
+/- : Use these buttons to select the amount of effect
in a sound mode and to adjust the channel"
Jan 16, 2011 | Pioneer VSX-24TX Receiver
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
What does the FL-CS-RF mean ? and how do u work it ?
Front Left, Center Speaker, Right Front. You may adjust volume level on each with the channel levels buttons -/+ directly under on the remote
Nov 30, 2010 | Sherwood RD-6105 Receiver
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
I have an Onkyo tx-sr605 7.1 channel receiver in which I have set up currently with only with 5.1 channel. The system sounds great, but I am finding that when I set the volume to a level to hear the...
After a long effort searching on Google, I found a solution. There is a Late night setting on the remote that limits the loud sounds scenes so it is not much loader than the dialog. Works great, I can't believe I never notice the button before.
Jan 20, 2010 | Onkyo TX-SR605 Receiver
Model ws-55711, remote doesn't work but I don't believe it is the remote control, can only change station up or down manually, cannot adjust volume or others manually...
If you can change channels with remote then TV is OK because it has only one infra red receiver (remote receiver) to catch remote signals.
So TV remote seems bad as it works on channel buttons only.
Here is an easy test for remote, watch remote front through any digital camera or even cellular phone camera will work and press channel button on remote, you will see blinking LED at front of remote while watching it through camera. Now press other buttons of remote and I'm sure that LED wont blink.
Sep 07, 2009 | Mitsubishi Televison & Video
How to vary the Multi zone levels at the receiver
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
CABLE GUY.
Jul 16, 2008 | Denon AVR-3802 Receiver
Panasonic SA-HE7 Receiver Logo
111 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
