Question about Soyo KM400 Chipset MotherboardAMD Socket A CPU, Model "SY-K7VMP2" - RETAIL
Floppy drive not recognizing disk, have replaced drive and cable. Also now the Via built in LAN is not working either. Should I just get a new motherboard?
  • 105 Answers
Before changing the motherboard, try re-installing the os and device drivers
Posted on Sep 25, 2009
My TEAC FD-05PUB is recognized by my computer. However, it will not open a floppy disk. It says the disk needs to be formatted (even thought the disk works fine on other computers with the same operating...
Try a brand new disk put something on it and go from there the disk you may be using may be no good anymore. Try this first before getting another replacement disk I would stop using these floppy and go to a USB Stick for storage purposes since they are going obsolete. Just a suggestion! That would solve your problem using floppies for storage besides they do not hold much information compared to todays storage devices. John
Jan 15, 2011 | Teac FD-05PUB External Floppy Drive
My external floppy drive will not install. Instructions say just plug and play. No software? How do I get computer to recognize
I don't remember if you can do the power savings on the USB port in XP. If you can, you access that through the Advanced Settings button of the Screen Saver tab (either Control Panel, Display Options or right click on the display anywhere there isn't a program window or icon).
Since your USB ports work for other devices, it may be that either the drive failed or that built-in cable has been damaged. To replace the cable, you would need to open up the case and desolder the connection and solder in a new cable. I can't advise you on that since I wouldn't have a clue of which wire would be which.
Mar 24, 2010 | SmartDisk (RF-FDUSB-TM2) (RFFDUSBTM2)...
Ican't get a self installed floppy disk drive to work with Vista.
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Sep 25, 2009 | Teac Floppy Drive 235HF Internal Floppy...
Winxp instalation
hi,
There is not way to install a windows xp os without SATA drivers. If you don't want to use the floppy disk to make the os recognize the HDD, you can integrate the drivers in the Windows Xp installation Cd, using software like Nlite.
Another solution is to use a IDE HDD, the old kind with the 80 wire ribbon cable.
Mar 31, 2009 | VIA ASUS A7V600X MB AMD KT600/ 400FSB/...
Memorex external usb floppy disk-drive does not appear or functio
As I understand it the computer recognizes the floppy drive.
Can you read other discs, write to them etc? If not drive is bad
If you can read other discs then your floppy disk is bad
Jan 23, 2009 | Memorex Computers & Internet
Gigabyte k8t890 m/b cannot find sata wd7500aacs drive
You must creacte a Floppy disk with SATA drivers so windows can recognize your SATA controller.
To creacte this disk you can boot whit your motherboard CD, or you can download dirver on gigabyte website and then copy it to a floppy.
If you are installing WinXP, you must press F6 when it asks if you have a third party scsi our raid controller.
Jan 14, 2009 | VIA Gigabyte GA-K8VT890-9 K8T890 Socket...
Troubleshooting Floppy Disk Drive Problems in Windowxp
try using the floppy on another computer, if you have the same problem then the floppy is bad, if it works on another computer then your floppy drive might be bad, if you built the computer, try using another cable for the floppy drive, i ran into problems like that when i put bad cables in
Dec 04, 2008 | Microsoft Windows XP Professional
Problem with disk drive A:
First, you should try to keep the floppy drive. If you can find one, I highly recommend getting the floppy drive cleaner diskette. They're hard to find now, but it's worth it if you want to continue to use your floppy drives. If cleaning it doesn't resolve the issue, next item to try is replacement of the floppy drive. You can borrow a floppy drive from someone, plug it in and test to side if it fixes the problem, if not, then it's either a motherboard issue (which I doubt) or a software/windows XP problem (more likely of the two). In which case I would recommend reinstalling windows XP to see if it fixes the problem before shopping for a new motherboard or a new computer.
Good luck
Jun 29, 2008 | Dell Dimension 2350 PC Desktop
Can not get new plug and play usb floppy drive to recognize floppy disks.
Did it work before?
If yes, then it died.
If no, then replace it.
Mar 16, 2008 | Computers & Internet
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Soyo KM400 Chipset MotherboardAMD Socket A CPU, Model "SY-K7VMP2" - RETAIL Logo
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
