Question about Motorola Mobility RAZR V3
Key pad dosen't work buttons do nothing
Key pad dosen't work buttons do nothing I can recieve calls the only button that works is end button to turn phone on and off
Buttons malfunctioning
The problem are in your ribbon wire or some us named Flexyble cable.the keypad that you told are connected with main engine with use a flexyble cable.so if flexyble cable were damaged the problem usually up keypad not working,sometimes no display(blank) or we hear nothing from earpiece.may it help.
May 24, 2010 | Samsung SGH-L760v Cellular Phone
I have a Verizon Moto Q. The buttons are not working properly. When I hit the start button, back, the arrows, or center select button, mail button and certain letters it just enters numbers or letters and...
Hi, from the question you posted, there are three likely problems to the phone. One it's either the key button pad is bad which needs to be replace, the interface of the key button pad is dirty which needs to be cleaned, or the glass I.C which controls the key button is bad which also needs to be replaced.
But i think what the problem is the cleaning of the key pad button interface because the buttons are working but they only misrepresent whatever function you try to perform on the phone.
You just need to get a mobile phone technician or an electronic repairer around you to help service and clean the board and key pad button interface, and the phone will start working fine..
Take care
Mar 26, 2010 | Cell Phones
End call button doesnt work--need help!!
u have to replace the carbon pad in phone
Feb 13, 2009 | LG Vu CU920 Cellular Phone
The key pad on my phone does not work
I have the exact same problem. It started yesterday but I didn't even check the phone until someone said they called and I never received the call. Then this morning the phone was off so I power it on and it said the battery was almos dead. I charged it but couldn't look at a text msg that I had received. Now the only button that work is the power button. I bet it has something to do with Verizon network. I will contact them to see what they suggest unless someone fines a fix sooner. Thanks!
May 30, 2008 | Samsung SCH-a950 Cellular Phone
Key pad on corless handset is not working
There is solution but it will only work if you are a handy person. The product is call ctrubber.jpgRubber Keypad Repair Kit and you can buy it here
Mar 31, 2008 | Motorola Mobility MD41 Cordless Expansion...
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
Key pad is frozen
is your phone been dropped or wet? check local service center near our place.
Sep 20, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Frozen key pad
I have the same problem. Was not dropped or water damage to my knowledge. Just the red button works. When I open it, though, it shows the asteriks key as being pressed which is under the #7 key. Any help would be greatly appeciated.
Sep 08, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility RAZR V3 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
