Question about Storagetek L80 DLT Tape Drive
No drive available (338)
I'm receiving an error message saying "unable to reset drive, no drive available (338)
When trying to access incoming messages, a box appears saying; not available, so I am unable to read any messages or even access previously received mail
maybe your inbox is already full... or you should reset your phone the default factory settings.. =) try it.
Jan 23, 2011 | Cell Phones
Will not record a program, can not access dvr recorded programs. When DVR button is pressed get the message " ERROR 024 Unable to access this feature at this time : data not available " .
Hello this is Matthew Gonzales with DISH Network customer service. With a 024 message, the best thing that we can do is hard reset the receiver. To do a hard reset, you simply unplug the receiver from the power outlet it is connected to, leave it unplugged for 20 seconds, then plug it back in. The receiver reboot process takes about 5 minutes. Once the show is back on, try accessing your DVR again, if it is still not working, the receiver will need to be replaced. If this is still a problem, please feel free to email me at matthew.gonzales@dishnetwork.com with your account number so we can get this resolved.
Sep 21, 2010 | DISH Network ViP722 DTV Receiver /...
Error message 24 - DVR not available
The 024 message means the hard drive itself is having problems functioning correctly. Try a hard reset where you unplug the receiver for 10-15 seconds and plug back in. If the problem persists a replacement may be necessary.
Jan 01, 2010 | DISH Network DVR-625 DTV Receiver /...
Unable to download or send pictures/video in text messages.
Try this website, it will send the correct setting to your phone.
https://motorolasetup.tarsin.com/home.htm?manufacturer=1&deviceKey2=V9
Please give good rating, it is very important to me...
Jul 29, 2009 | Motorola Cell Phones
Windows was unable to complete the format 16gb kingston flash drive
windows was unable to complete the format flash drive
Apr 28, 2009 | Computers & Internet
Unable to send/rec pictures SE W850i
I think the problem here is with your connection. I understand that you have the right settings from your operator...however you should check with them to see if your line is data enabled for MMS (this is how your pictures are sent....in an MMS message).
Feb 22, 2009 | Sony Ericsson W850i Cellular Phone
Screen is stuck
Did you try to remove the chip yet?, sometimes that helps, and re boots the system?
Failing that, try to remove the battery, to enable the unit to completely power-down. Then refit, and try again.
There is a reset function, but i am assuming you are unable to access that if the screen is frozen.
I have listed how to remove the battery on another post on here.
Good Luck
Jan 30, 2009 | Navman iCN 330 GPS Receiver
File system error 1073741521
As per the error message you had received, I beleive that the File System (Partition Table) in your Hard Drive is curropted because of which you are unable to store any data.
The only option available is to burn the requried data into DVDs and perform full recovery and reinstall the Operating System to factory default settings.
This will format the Hard Drive and will also recreate the File System (Partition Table).
Oct 29, 2008 | HP Pavilion dv9000z Notebook
Storagetek L80 DLT Tape Drive Logo
364 people viewed this question
Top Storagetek Computers & Internet Experts
David Payne
David Payne
Are you a Storagetek Computer and Internet Expert? Answer questions, earn points and help others
