Question about MyMusix PD-6030 MP3 Player
It shuts off when i connect to the usb
When i plug into the usb, the mpe player shuts down. i then replace the battery and it does it again
  • 8,596 Answers
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Posted on May 24, 2008
Vivitar mp3 player isn't recognized by computer
If the MP3 player is not charging through the USB cable when connected to the computer and the computer cannot detect the MPe player then you could have a faulty USB cable. Try a different USB cable.
May 02, 2012 | Vivitar Digital Mp3 Player - Black
PMP-120 Battery Discharges too quickly
Yes,
you will have power through the usb port, so leave it plugged in.
Even when it is shut down it can drain batteries.
Feb 25, 2008 | iRiver PMP-120 Digital Media Player
Need a charger
MPe players are charged using the supplied USB cable by connecting it to the USB port of a working computer or by a 5 volt USB mains adapter.
Mar 03, 2012 | Polaroid Audio Players & Recorders
I ahve a no name mpe player and try to sart it and it just comes up with the loading symbol but will not go any further
Hi there
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Sep 16, 2010 | Jwin MP3 Player
I shut down the computer while charging my mp3
Try plugging in the USB connection again. If that doesn't work, unplug it and then press and hold the on button for ten seconds.
May 06, 2010 | SanDisk Sansa e250 MP3 Player
I have a Zvue Spirit Mpe Player n iduno how to put music on it I really need help
To put music on your zvue spirit mpe player, you will need a computer system that you have music on already. i mean you must have stired some music on the computer system
I believe your zvue spirit player came with a usb cord, connect your zvue spirit mpe player to your computer system.
Go to my computer on the desktop of your computer, right click and open, you will see a drive or an icon representing your zvue spirit mpe player.
right click on it to open and create a folder that you want to store the music on.
Go to your computer system where the music are stored, highlight all and right to copy. Go to the folder you created on your zvue spirit mpe player, open the folder and right click to paste the music you copied from your computer system in it.
Safely eject your zvue spirit mpe player and go to the folder you stored the music to see all the songs.
Take care.
Apr 25, 2010 | Zvue Spirit MP3 Player
Nextar MA715 MP3 player wont take a charge.
Best first bet is dead battery. If it is a special battery then do the costings for the repair as it may be cheaper to replace the player.
Jun 13, 2017 | Nextar MA7151B MP3 Player
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
Hey
It is easier to reformat the mp3 player. When the mp3 is plugged in to the PC, go to my computer, the double click the mp3 player there. You will see internal storage, right click that and click format. You will lose all the stuff on the mp3 player.
Oct 26, 2007 | RCA Lyra RD2765 MP3 Player
MyMusix PD-6030 MP3 Player Logo
32 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
