Question about Refrigerators
TFC27ZFS GE frig will dispense water then continue to leak water and doesn't stop?
  • crites679 Sep 24, 2009
    Thanks, It doesn't just drip out it a very slow stream of water. It sounds as if this double valve must be bad
  • 4,059 Answers
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Sep 24, 2009
Testimonial: "Thanks, It doesn't just drip out it a very slow stream of water. It sounds as if this double valve must be bad."
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Mar 22, 2010 | GE Refrigerators
I have water leaking under front at late night
Check your ice maker lines that run in front at the bottom of your frig. You just might have a small leak in the line.It's located behind the grill in front of the frig.
Dec 15, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
Model#a4425gd2aww;water dispenser stays on witout pushing cradle even when ice selection is on. This is an americana refridgerator made by GE.
Disconnect the wires on the water valve.(or unplug the frig) If the water stops the dispenser control is defective. If the water continues the valve is stuck and needs replacing.
Eric
Oct 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Water drip at doorfront water dispenser
Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
Jan 03, 2009 | Refrigerators
GE side by side fridge/freezer. Water stopped comming out the dispenser..
Hello.
If your frig only has a dispenser for water, the first thing you need to check, is the shut off valve, which is sometimes under the kitchen sink, and make sure nobody turned it off for some reason.
If you have a frig that dispenses both ice and water, and only the ice is working but you aren’t getting any water, then it is probably the water side of the dual water valve that has gone out. A lot of times the water side of the valve will go out before the icemaker side, because it tends to be on longer due to people filling up glasses and pitchers.
If you hear water running when you try and get water, then you probably have a leak in the water line that goes to the dispenser.
Another thing that is rare is the water will freeze in the reservoir that is behind the crisper drawers in the fresh food compartment. This sometimes happens when it isn’t used enough.
Nov 30, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
