We have a OCE CS 4032 Scanner. The unit will not
We have a OCE CS 4032 Scanner. The unit will not boot up. None of the lights work and when the unit is turned on it makes a low clicking noise.
2 Suggested Answers
SOURCE: Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Posted on Sep 22, 2010
Copystar cs-1815 error code 3200, how can it be fixed
If it is a c-3200 code it means that you have a exposure lamp problem.Defective scanner,defective scanner PCB,lamp or inverter board,incorrect shading,poor contact of the connector terminals on lamp assembly. Look for a bad connection And look at lamp. Look for blue rings or burnt ends. Now don't look at that light while its on.
Feb 02, 2015 | Copystar Office Equipment & Supplies
OCE cs 2236 printer error message e196-404e sur
WHAT IS THE SIGNIFICATION OF ERROR CODE E196-404E FOR PRINTER OCE CS-2236 ,
Jul 03, 2014 | Canon imagePROGRAF IPF710 Printer
Oce tcs500 scanner - error code 10514-246 scan failed. any solution for fix?
Repair of oce scanner with error code 10514-246:
The customer Service said that this error means there is not enough light reaching the camera and we have to let them replace the lamps. cost:1500€ :(
solution: i removed the backplate of the scanner (3 screws) and cleaned the lower mirror. it was that dirty that i nearly didnt find it. it is placed on the groud of the lower big hole behind the backplate.
After that i recalibrated the scanner and now it works fine again.
I hope this helps since there is no correct exlanation of this error on the web.
Nov 01, 2013 | Office Equipment & Supplies
OCE Copier CS 231 - error code C3822
hello le menu reseau pour confoguration tcp ip est disparu quel qu'un peut m'aider
May 31, 2012 | OCE Office Equipment & Supplies
My Oce Scanner has the 10514-246 error. Please help me !
my oce tcs500 error code 10514-246 start of scan failed
Sep 07, 2011 | Office Equipment & Supplies
I need an Operator's Manual for the OCE CS 4035 scanner.
Google it, they have it. I found the manual for the Oce' copier so I could check out the scanning mode. Hope this helps.
Mar 18, 2011 | OCE Office Equipment & Supplies
I forgot the password for key operator oce password, in order to configure the scanner for the Oce tcs 500 i cannot put any path for the scanner unless i log in . please i need help asap. thanks.....
The Key operator password: KeyOp
The System administrator password: SysAdm
The Service operator password is: Please send an e-mail for me!
diplomamunka (at) citromail.hu
Apr 22, 2010 | OCE Office Equipment & Supplies
Where ci get a work shop or service manual for a OCE CS 2124 wide format printer
where do I get a service and repair manual for a OCE CS2124 wide format printer
Dec 12, 2009 | Office Equipment & Supplies
Oce vs. Xerox Recommendation
I can't speak for the OCE model, but I have worked on the WCP 7345 (I'm a trained Xerox tech), and I find them to be very reliable when it comes to recommended repair cycles and overall wear-and-tear of consumable parts.
Aug 21, 2009 | OCE Office Equipment & Supplies
Oce tcs 500; system administrator passwork
I am guessing this is a Windows XP system that it is connected to. Reboot the computer and as it is booting press the F8 key. It should bring up a menu for boot options. Select Safe Mode and at the log in screen select Administrator with no password. In a lot of cases this will get you in so you can go to the control panel and remove or reset the password.
If that doesn't work you can also search on google for XP Administrator Password Reset CD.
Cheers
Jan 03, 2009 | Office Equipment & Supplies
760 people viewed this question
jasbo
jasbo
