Question about Refrigerators
GE Refridge #tbx21jablraa Water collecting in
GE Refridge #tbx21jablraa Water collecting in the bottom of the fridge. We have to wipe it out a couple of times a week-more when it's humid.
  • 1,543 Answers
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
Posted on Sep 24, 2009
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
What does it mean when water sits on bottom of veg. drawers,wipe up comes right back next day,refrigerator 11yrs. old,ge,brand
Try to lean the fridge a little backwards through the little screws on the bottom front on the fridge also cleaning the filter helps
Feb 27, 2011 | GE Refrigerators
My profile ge fridge leaks water and the water pools at the bottom of the fridge. What is the cause please. Thankyou!
There could be overflow at the deffrosting tray and the excess water is flowing out of the collection tank.
You can get access to the tank which is at the rear bottom . Open the sliding cabin to take the drain tank to be emptied.
Sometimes heavy frosting in the coil can result in this build up and cause the over flow.
You must take a look at the source of flow to finalise.
Please comment.
Aug 31, 2010 | GE Refrigerators
Water collecting at bottom of fridge. GE 17 Model 34769-3
pull bottom tray and look for hole in the back on the bottom try a clothes hanger straightened out and push thru hole
Feb 06, 2010 | Refrigerators
Ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Aug 11, 2009 | GE Refrigerators
Freezer is cold and collecting frost, refrig isn't cooling.
you may have to remove the floor of the freezer. At times they fill with water and freeze. and you cannot see the layer of ice under there. This ice can form in the channel that allows the cold air into the fridge. another suggestion would be to put the fridge on the lowest setting then raise it up about 3-4 hours apart. hope this helps. Good luck.
Apr 24, 2009 | Refrigerators
Water in refridgerator interior
sounds to me that your drain line in the back of the refrigerator is clogged up. Take a wire and around 2 gallons of hot water and clear it real good.
Mar 20, 2009 | Camco Battery Fridge Refridgerator Alarm...
GE Profile TBX22PC fridge water problems
hi thanks for the question you have a drain problem the drain tube from freezer to the drip pan behind and under neath the fridge you have to clean that drain sometimes you have to shut the fridge down for 24 hrs let the ice melt in the drain tube cause you cant get at it so let thaw and then clean out the drain hose thanks for your question the appliance doc
Sep 18, 2008 | Refrigerators
Water build up in bottom of refridge
there is a blockage in the drain from the fridge. I am assuming that it is a conventional fridge with ice on back wall. half way down on the back wall, there is a sloping gulley with a drain in the middle. push something flexible down the drain to clear
Jun 29, 2008 | Refrigerators
Refrigerators Logo
209 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
