Question about Intel D845GLLY Motherboard
The bios repport only 64 mb ram
I have a intel 845glly desktop board ,i insert a pc 133 256mb ram on this motherboard but the bios report only 64 mb ram.please any one can help to solve the problem
  • 104 Answers
Ram module may be bad or incompartible. try another one
Posted on Sep 25, 2009
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
PZ TELL ME ABOUT WHICH PROCESSOR(CLOCK SPEED) SUPPORT INTO 845GLLY MOTHER BOARD
845GLLY supported processors:
1.6GHz to 2.4 GHz Pentium 4 processors with system bus frequency of 400 MHz, for more information follow this link: http://support.intel.com/support/motherboards/desktop/d845glly/sb/cs-012859.htm
Apr 29, 2009 | Computers & Internet
The 256MB SDRAM is showing as 128 MB SD RAM
if you have onboard graphics card that shares the ram memory with your graphics card then the configuration in the bios will determine how much memory is shared with your graphics card so you will lose memory there. Also windows xp does not always report the correct amount of memory so check with cpu z or wcpuid or another utility to check.
Also when you restart your computer when it detects the memory how much does it show that is installed there or if you go into the bios does it show the correct amount.
If it does not then it is not compatable and I would suggest going to www.crucial.com and selecting / getting the correct memory by selecting the correct computer / motherboard that you have.
Apr 10, 2009 | Computers & Internet
Loss of Ram in D102G intel Board
hello, you just have a shared memory with the on-board ati graphics, if it's on- board graphic card it shares the system memory-most are adjustable through the system bios-in 64,128,256 settings. and if you put more memory, in most cases it will automatic-raise the memory size of the graphics memory. i hope this helps you, all the best. if you need further assistance reply. don't forget to rate this solution.
Mar 25, 2009 | ASUS P4B533-VM Motherboard
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Probblen in Additinol RAM
Hi Raj_jp, the Intel D845GLLY board must have SPD memory to function correctly in the system. The memory you added (512MB) must not support SPD. To help you understand what SPD is, you can click on this link which explains what SPD is.
http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci533524,00.html#
The memory sold in this next link will function in you're Intel motherboard. http://www.memory-up.com/Memory/IntelD12696.html
So will the memory in this next link.
http://www.memorystock.com/memory/IntelD845GLLY.html
If you bought the 256MB memory recently, you should be able to return it & have it exchanged. The link above also lists the part number for the memory.
Good Luck!
Remember you're Intel motherboard uses you're system memory to run the onboard video card. The total amount of memory the video card uses can be adjusted higher or lower. You can adjust this in the bios. Go to Advanced Menu. Page 40 in the Intel user manual. You can download you're manual at this link.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
Mike
Jun 02, 2008 | Intel D845GLLY Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
RAM installation
download express installation for bios update from http://www.updrivers.com/bios/Motherboard/Intel/12/176.html
put on one ram only in windows run your bios express installtion
file
Apr 13, 2008 | Intel D845GLLY Motherboard
Intel D845GLLY Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
