Shop says that moms 1982 chrysler distributor has a wire problem inside. he soldered it but says that is should have a new distributor preferably bosch. i have a rebuilt bosch from my 1984 volvo but it is set up for a plug not the pig tail like the 1982. is there a way to get or make a plug to adapt the later bosch un it to the 1982?
SOURCE: 1984 volvo is using lots of fuel and gas is coming out the tail p
Make sure the fuel is not being pulled in from the charcoal canister.
SOURCE: order of spark plug wires
here you go
Firing Order and Reinstalling Plug Wires:
B230F/T or B234 Four Cylinder: Firing order
1-3-4-2.
SOURCE: 1987 Volvo 240 DL...hard-wiring the brake/tail lights...
Solder to the circuit board, just in case they interact with other circuits.
SOURCE: where can i get a rebuild kit for a 1982 volvo
I would not suggest doing this repair yourself. It is a difficult job for a seasoned mechanic. I don't even rebuild them, I just get a remanufactured one from NAPA or Pep Boy's. Going thru Volvo will be even more expensive. You can go to Partsgeek.com or Autohause.com for replacement pumps. Is it leaking? I would also look into replacing the injectors at the same time along with the fuel filter.
