If your Kenmore washer series 400 model 22102 is dripping water in the tub after the cycle is complete, there could be a few potential causes. Here are some things to check:
Water valve: The dripping could be due to a faulty water inlet valve. This valve controls the flow of water into the machine and if it's not closing properly, water can continue to drip into the tub even when the cycle is complete. You may need to replace the water inlet valve to fix the issue.
Water level sensor: Another potential cause of dripping could be a malfunctioning water level sensor. This sensor tells the washer when the tub is full and it's time to stop filling with water. If the sensor is faulty, it may not be accurately detecting the water level, which could lead to dripping. You may need to replace the water level sensor to fix the issue.
Drain hose: If the washer is not properly draining, it could also lead to dripping after the cycle is complete. Check the drain hose for any kinks or clogs that could be preventing water from draining properly. You may need to clean out the drain hose or replace it if it's damaged.
Overloading: If you're overloading the washer with too much laundry, it could be causing water to overflow and drip into the tub after the cycle is complete. Make sure you're following the manufacturer's guidelines for load size to avoid overloading the machine.
If you're unsure of how to diagnose or fix the issue, it may be best to consult a professional technician or reach out to the manufacturer for assistance.
You may be looking at residual water dripping down from the rim. If the drip is located near where the water fills from, then you may have a water valve (could be either hot or cold side) that is not able to close completely. The valves are typically replaced, but sometimes cleaning can help for short term. Consult your user manual for removal / replacement instructions.
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Good day, If water constantly runs or drips into the tub,even if the machine is off, then the water valve in the back of the machine, has one of the seals failing, and the water valve needs to be replaced.
