Question about Linksys Wireless-G WRT54G Router
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using the Linksys router. It connects to the network but does not display any internet pages.
  • 80 Answers
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Posted on Sep 24, 2009
Dell inspiron e1405 cant acquire a network address?
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
May 17, 2017 | Dell Inspiron E1405 Notebook
Laptop wont connect to wireless network but desktop is fine.
Perhaps, it just needed a new IP address. Simply rebooting the computer and resetting the IP Address of the computer took care of the issue.
or
That sounds like symptoms of Manufacturer & Windows drivers conflicting. Try uninstall the Manufacturer Drivers and let the windows ones do the work, and see how that goes down.
Apr 20, 2010 | HP Mini 1000 Netbook
Just set up my g broadband router. Unable to connect to internet
Your laptop may not support g wireless. Change the wireless to broadcast B and G
Nov 15, 2009 | Linksys Wireless-G WRT54G Router
Unable to access the internet via my laptop
One of two problems. The Security Key for your wireless connection is wrong, or the McAfee is causing a problem. Most likely conflicting with any other virus software on your computer. Try removing McAfee from the computer and your solution should go away. Try another virus software such as Avast! Home edition. McAfee is known for having issues with wireless internet connections.
Gary
Jan 25, 2009 | Linksys Wireless-G WRT54G Router
Unable to connect to my wireless network connection (SSID still VISIBLE)
Log on to the router, go to your wireless setup page. Disable wireless, reboot it and when it comes back up, enable wireless once more with a different pre-shared key. You'll need obviously to enter this new key into your laptops. Let me know if this solves the problem.
Nov 09, 2008 | Linksys Wireless-G WRT54G Router
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Unable to actually connect to the internet?
Have you tried restarting your router? If not, try unplugging the ac power from the router, wait 30 seconds, and plug it back in. That will usually take care of this problem. If that doesn't work, you can try going into "manage your wireless connections", delete your wireless network from the list, then reconnect to your network.
May 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
Wireless configure laptop
You may be getting a little mixed up; the SSID is the dispayable name of the router over a network and the code you may be refering to is the WEP or passkey for security. First go into your routers settings and ensure that the DHCP is enabled to automatically give the laptop an IP address. Check your laptop wireless adapter/reciever is set in the properties to obtain IP adress automatically. Turn off any encryption you have running on the router and restart both router and laptop. When laptop boots it should again find all the wireless networks in you locality, then click on your network and click connect. If all works fine go into router again and then set up security key and note whether it is an 'open' or 'shared' network access as you may need to input this into your laptop if it is unable to reconnect after the restart. Also if your wifi signal is relatively low, it will not allow a connection to the internet as it is unable to send data at a low signal rate. If you originally ran the router via an RJ45 network cable, you may need to clear the dns from your laptop, click Start>Run, then type ipconfig /flushdns and restart your laptop to give it a new ip address and dns address.
Mar 12, 2007 | IBM ThinkPad T41 Notebook
Linksys Wireless-G WRT54G Router Logo
219 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
