Question about Refrigerators
U-Line 15WCSS (wine refridgerator) not working.
Opened the wine cooler one day and it was very warm inside. The unit seemed like it was not on, could not hear any motor running. Turned to OFF and turned back ON, nothing happened, no sounds at all. Any thoughts?? thanks, Tom
  • tserv Dec 16, 2007
    Peyton-Thanks for the info!! Do you know if I would gain access to the thermostat from the front of the unit, up the
    toe grille section of the unit. thanks again!!! Tom
  • 410 Answers
Most likely the thermostat is bad not bringing the unit back on. the thermostat is the temperature control knob located in the toe grille of the unit. on the u-line unit replacing the control can get kind of involved but if you will follow the directions supplied with the part yyou can do it your self.
Posted on Dec 16, 2007
  • peyton thompson
    peyton thompson Dec 16, 2007
    yes by removing your toe grille you will see a little box that houses the t-stat. if you wanted to test to be sure just remove the 2 wires that are connected to the thermostat and conncet them together to make sure compressor and fans start up.
I see the two wires that are connected to the thermostat, they both have a plastic end. How do I go about placing these two wires together, ie...cut off the plastic ends, strip the wires and then place together?? Please let me know your thoughts.
thanks, Tom
Posted on Dec 17, 2007
You could just jump them together with a clip (make sure the jumper does not touch ground and the power is disconnected while trying this). A safer way to go would be to check the control continuity with an ohmeter. The contacts should be closed in any knob position except off. You can get a part or additional advise at or 1-800-779-2547 (U-Line customer support line)
Posted on Jun 27, 2008
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Does not cool the wine,back panel is warm and unit is making a no
If your condensor fan is running and the compressor is running then you will need a tech to look at the sealed system for you.
May 26, 2009 | U-Line 15WC Wine Cooler
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
Frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Sep 05, 2008 | Marvel (6SBARBSG) Wine Cooler
U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
May 20, 2008 | U-Line 75WC Wine Cooler
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Water leaking from unit
It may be the drain line is not dripping into the catch bucket under the back side, visually check to see if the line is reaching into the bucket and that it's not clogged up on the inside of the unit floor. The back panel being wet may just be condensation in between cooling cycles as the frost melts. If the unit is OK with keeping temps the refrigerant charge is likely OK.
Nov 21, 2006 | Haier HVF060A Wine Cooler
Refrigerators Logo
453 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
