Question about GE (PSS26MSRSS) Side by Side Refrigerator
I push the water dispenser and no water and no sound but a click.
I had this happen about a year ago and I took off the filter and run some water thru and it worked again. This time I took the hose off at the bottom and no water came out. I cleaned the filter which is onlyt 3mths old.Then I check to make sure water was getting to the filter and it is. Then I pushed on the water disenser and after about a minute I got water. the next day I tryed the water and the same no water and just a click.
maybe not related but the top vent in the non- freeze part is not blowing any cold air. There is nothing coming from it at all.
  • 1 more comment
  • bigdaddyt Dec 16, 2007
    if you are ask if the pipe has a hole no, all is good on that front.
  • bigdaddyt Dec 18, 2007
    I have defrosted my frig and now the water is working from the water dispenor but now the ice is hollow any ideas
    Do have any iadea on how much that could run to be fix? I had a new frig on it way a day ago then this one started working agian so I stop the order. So now I need to see if it is cheeper to fix a six year old frig or get a new one any help on cost would be great
  • 328 Answers
Sounds like the water pump is faulty or the water is freezing inside the tube and you could have an ice blockage. GE does have a heater available for this unit. You have to contact them directly to get this part at 1-800-626-2005 This is a repair best left to a professional if under warranty still. Other option is to do it yourself but it would not be easy if you are not prepared to tackle it.
Posted on Dec 18, 2007
  • Lyle Siemens
    Lyle Siemens Dec 19, 2007
    I do feel bad for your situation. I am sure you paid big money for it a few years ago. I suggested probable problems because I have not seen it, I cant give you a for sure answer because there may be more than what I suggested wrong with it including rust deposits. . The cost could easily run into over a $1000. Read this link about GE refrigerators and decide for yourself.
    http://www.consumeraffairs.com/homeowner...
    My suggestion would be to re-order that fridge and stay away from GE. Good Luck
  • 456 Answers
The pipe is puncture from anyside
Posted on Dec 16, 2007
Water not dispensing
new installs require one to hold down the dispense button sometimes as long as 3 min to allow the water to make its way thru the filter and lines and allow the air to get out , also if you have a well , I have run across one that didn't have enough pressure to push thru the filter when it was new ,as it takes at least 40 psi to push thru a dry filter when its new , it doens get easyier when its wet
Mar 17, 2016 | Refrigerators
Whirlpool Gold Series Refrigerator has foul tasting water and ice.
and what does the water elsewhere in home taste like .is it city water or well water . usually you can take a sample to local health dept and they will test it free .
May 20, 2015 | Whirlpool Refrigerators
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Chemcial taste in water after changing water filter
Well this never happens with me but surely you might get some unusual result.
Chlorinated Solvents Exporters
Sep 12, 2012 | Whirlpool Gold GSS26C4XXB 26.4 cu. ft....
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Hello, lost water in the house, now when it came back on, water dispensor has a slow drip (not sure if related)... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't...
remove bottom grill.
look for tube which runs thru freezer door.
follow back towards underneath of machince/ find push fit connector.
remove pipe which run thru door from connector and blow thru quite hard. reconnect and press dispenser paddle to allow water back thru
this shhould solve problem in 9/10 cases if it doesn't then you will need your water inlet valve checked
Jan 27, 2011 | Whirlpool Refrigerators
Water dispenser quit dispensing 2 days ago
Sounds like the micro switch has gone bad behind the dispenser cover. locate your handle or push button either you will remove the front cover to find the switch sometimes you remove inside the door behind the dispenser. but that sounds like the trouble your having. Maybe I've helped good luck. BB
Jan 21, 2010 | GE GSH25JFR Side by Side Refrigerator
IWater does not dispense.
Good day,
The hum is normal. That's the water valve in the rear of the machine being activated.
Lots of plumbing to be checked.
Water line starts at the dispensing outlet in the door, and runs thru the door to the bottom of the hinged side.
From there it goes to the filter,
'From there it travels under the machine into the cooling reservoir mounted back of the fresh food section behind the crispers.
From there it travels back out and runs to the water solenoid mounted on the back rear of the machine.
One of these lines or their fittings has failed.
It's a look-see repair.
Also, there is a remote chance the water line running inside the freezer door froze, causing this problem, and would require the machine be shut down (unplugged) and the door be allowed to defrost completely.
Nov 16, 2009 | KitchenAid Refrigerators
Whirlpool side by side, 7 years old. not making ice
try using a hair dryer to thaw out the trough and remove the ice. please note the ice will run all the way up into the tube where it comes thru the cabinet.
this may have occured from your recent filter change as a new filter introdues alot of air into the water system and will cause these tubes to freeze up. in the future right after you replace your filter be sure to run aout 1/2 to 1 gallon of water thru water dispenser to clear air out of system. thx peyton
Jan 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Mar 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
54 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
