Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
All lights & horn work, battery showing full charge, won't run, not even a clic. Key turns on, controll unit flashes 6 times in repetative cycles...Any ideas?
  • Electric Mob... Master
  • 1,263 Answers
Ok, that can be a number of things, first of all trying moving the throtle to the left slight then turning on, thry the right side as well, now the idea is if the pot (wig wam etc) has moved it means the throtle is in hte wrong location otherwords a error ,
Regards
GeWiz.
Posted on Oct 01, 2009
Pride gogo sport motor just quit while going along a sidewalk.
Hi it's possible the control box down timer was activated check if freewheel lever is in drive remove key & wait a few minutes replace key & turn on cheers.
Nov 09, 2017 | Pride Health & Beauty
Headlights not working, rpm gage not lighting up, neutrel light not coming on
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Davidson Sportster error codes and how to access them
Dec 15, 2013 | 2000 Harley Davidson XLH Sportster 883...
2001 heritage softail that won't start, please HELP!!!!!
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
May 11, 2013 | 2000 Harley Davidson FLSTC Heritage...
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
ENGINE WILL NOT TURN OVER/SPEEDO AND TACH LIGHTS FLASH
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
Harley Diagnostic Codes 04 to Present
Jun 04, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Cannot diagnose source of electrical fault
TRY A TO BYPASS ALL SYSTEMS WITH A POSITIVE LEAD SHOULD WORK BUT YOU NEED AT LEAST 9VOLTS TO GET THE IGNITER TO EVEN THINK ABOUT LETTING THE COILS HAVE ANY POWER TO EXPLODE THE GAP POINT OF YOU'RE SPARK PLUGS SO GOOD LUCK
Jun 14, 2009 | 1997 Yamaha XVS 650 Dragstar
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
398 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
