Question about Xerox DocuColor 12 Color Copier
Hi, I have a 9-354 error on my Xerox DC12. Can you help?
  • 12 more comments
  • rick_kordows Sep 24, 2009
    Hi, I have a spare DC12 that I can use for parts. Where can I find the 'crum'?
    I Have a spare DC12 that I can use for parts. Where can I find the 'crum'?
    Hi, many thanks for your assistance so far. However, I have replaced the copy/print cartridge. The belt looks ok and the developer housing unit turns manually ok and each developer roller turns ok. I got the 9-354 error in the middle of making a copy, if it helps.
    Hi, can I do a quick test/check to see if the ADC is working?
    Hi, can I do a quick test/check/visual to see if the ADC is working on my Xerox DC12 (without the machine being on)?
    I have rested the machine. But the error is still there. Is there a 'workaround' to get past this error? (9-354 Xerox DC12).
    Hi, I have replaced the whole transfer belt assembly from my spare DC12. Everything is clean but I am still getting error 9-354 a a couple of seconds after start-up.
    Hi, I have shook up all colours (still get error). Is there one particular colour this error code (9-354) refers to?
    I will do that in a moment. The machine has been complaining that it was out of yellow, now and again, for a couple of days. I think you are on the right track!
    Hi, I have tried several (new) yellow toners. All shaken first. But the error is still there. Do you know where the sensor is?
    I have replaced the 'whole' toner assembly with another. Made sure all toner chutes are full. All toner cart are new. Still getting error 9-354 ! Can anyone help.
    Hi Mike, Many thanks for the info. I have tried new toner cartridges. Still get error 9-354. I cannot find any evidence of crum chips on the toner cartridges. Would the error be referring to another crum somewhere?
  • rick_kordows Sep 25, 2009
    Well done Mike. That worked a treat! I have been asking experts all day ? you?re the man!!!
  • 315 Answers
Hi Rick,
All I can seem to find at the moment is this:
09-354: Xerographic Module CRUM not detected
9-xxx Codes are all Xerographic problems such as toner problems, developer problems, Drum Cartridge problems, ADC (Auto Density Control) problems too.
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge so If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
If you have recently changed the toner, then check that everything is located correctly, if that doesnt work, it might be worth trying another toner cartridge.
You probably wouldnt need this but you can have a look at the Diagnostic Menu:
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what (not menu driven… see our website)
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Have a look here for a little bit more information on the CRUM:
http://www.xeroxtechnology.com/crum
Hope that helps
Mike
Posted on Sep 24, 2009
  • Mike Neath
    Mike Neath Sep 24, 2009
    hmmm, as far as im aware the crum is only on the toner cartridges, I cant say im familiar with the actual location of the chips either.
    if we knew where exactly we were looking maybe we could fix it, could possibly be a faulty sensor else where as you suggested.
    I keep coming up with the same solutions everywhere I've looked though and as you've already tried several different toner cartridges I'm tempted to think that its not the toner crum thats faulty but the actual sensor inside the printer that reads the crum chip.
    Why is nothing ever easy eh.
    I'll have a chat to a few guys at work to see if they can shed a bit more light on this as I probably wont be of much help at this stage.
    Sorry I couldnt help more.
    Regards
    Mike
  • Mike Neath
    Hey again Rick,
    I've managed to get some information:
    If its an 9-354 error (?). Then set NVM to 776-060=0 and 776-372=0
    I'm only guessing that this would be found in the User Interface I posted earlier and would be found in the NVM Read / Write section.
    I hope that helps
    Mike
    President:
  • 1,462 Answers
But 9-354 indicates empty toner, Still if your toner is not empty there may be some blockage in the tomer
Tbe blockagae may prevent the toner from falling, If you remove the toner drum and shake a little and load the drum, should solve your problem
Please leave me comment, If you need furthur assistance
RNJ VINOD KUMAR
  • Vinod Kumar
    Vinod Kumar Sep 24, 2009
    Yes this color mainly deals with YELLOW TONER, Check whether the yellow toner is empty or try shaking it..
    Please leave me comment, If you need furthur assistance,
    RNJ VINOD KUMAR
  • Vinod Kumar
    Yes the yellow toner may be empty,
    PLEASE TAKE SOME TIME TO RATE MY SOLUTION IF IT WORKS
    THANKS, RNJ VINOD KUMAR
    President:
  • 1,653 Answers
The 9-354 error is acalibration error so you can either rest the machine and run the calibration from new or call in a service engineer.
  • Karl Wright
    Karl Wright Sep 24, 2009
    This is related to the timing of the transfer belt being out of range.This may be due to the reflector patch on the transfer belt being dirty so the timing sensor is missing the patch as it rotates. It can also be caused by the transfer belt slipping or the sensor itself being faulty and not recognizing the belt reflector patch as it passes by. This will need a service engineer to fix it.
    President:
  • 497 Answers
I couldnt find what your exact code represents. But i would check your toner, and cartridges. If you havent already. Otherwise it may be wise to get the ADC checked out.
  • 10,515 Answers
The above error means :-
9-354 = no crum found on xerographic module
You need to have the service manual in order to get this rectified. However, i would advise you to call Xerox for this.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 24, 2009
    Thanks for your response!!
    It's not easy for a user. You need to have a tech. This is a complex machine.If you want to try user level solutions, i suggest you, to remove developer housing from machine and clean donor
    roll, it is roll which transfer toner to xerographic belt.
    It should be light blue color, then check your photoreceptor belt life counter, if it is over 125000 copies, replace it.
    Hope i helped you.
    Thanks.
3 Suggested Answers
jaiku
  • 79 Answers
SOURCE: Service manual or a Service Engineer for Xerox DC12 machine
in every city xerox service center is ther... better u contect local xerox service provide.. becoz they only providing goood and quality service.. and may i know ur place?
Posted on Aug 16, 2008
SOURCE: Xerox DC12 Error code 9-355
mi da errore 3- 355 cosa devo fare?
Posted on Jun 10, 2009
Am haveing xerox dc12 , and am faceing error code 9-357
Hi especially you will get this error-9-357, if the Black Toner Dispenser Broken.
Mar 08, 2011 | Xerox DocuColor 12 Printer
Prize
Have a Xerox DC50 with error 9-378 drum cartridge count expired message.
How do i reset that. Please somebody
Mar 21, 2010 | Xerox DocuColor 12 Printer
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
My dc12 don't print good. They print as shadow
If there is a shaddow on the printed documents, then it may be you drum needs replaced in the printer...
Hope this helps.....
Oct 28, 2008 | Xerox DocuColor 12 Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
SERVICE BOOK
If you go to www.xerox.com and to the support and download area.
Type in DC12 in the search and then to downloads and drivers.
Select documentation and there is a variety of user support documentation to download.
Dec 13, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
