You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
I see you said you looked and the water valve is off but the only that I know of this happening is a defective water control valve. Like a dripping faucet that when off slowly drips until the ice forms and then one the ice maker dumps ice and tries to refill the water goes in every direction. Unplug water valve to confirm what I am saying, Tell me if it continues to leak. Sea Breeze
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tubemay be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey basterwill usually clear it out. Flushing
it out with hot water and clorox may help.
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water fromdispenser while your checking (Might only leak when water dispenses
