Question about Procom ML300TBA Heater
Thermostat can I use a remote wall thermostat with the ml300tba heater? I am using it in my shop, and I want to be able to turn the temp. up or down at the door as I enter and exit. My heater is on the other side of the room.
  • 188 Answers
These units are only made with a built in themostat and controls only. You cannot purchase an external thermostat or remote for this unit. Sorry...
Posted on Feb 08, 2010
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Heater warms up but doesn't get hot. Could it be the thermostat or antifreeze?
This would most likely be caused by a defective engine coolant temperature control thermostat. There are other issue as well you need to be aware of, is the cooling system rusted or contaminated? If so the heater core could be partially plugged. Another factor is the part called the blend door, does it move all the way to open the air flow passage across the heater core? I would start by inspecting the coolant and replacing the thermostat.
Please rate my help for Fixya, it improves my status and it is all I ask for my time helping you with your problem. Thanks
Jan 18, 2012 | 1994 Plymouth Voyager
Heater will only go up to 89 degrees.. using the remote. do i need to set the temp at the main heater
The temp at the heater should be set to maximum when using a remote. The remote can only go as high as the thermostat setting on the heater.
Apr 10, 2011 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
I have a wall heater that I don't know how to turn
Open the little door panel with the knob and turn up the thermostat knob. Down on the front.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 13, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Nov 06, 2008 | Heating & Cooling
Heater will not stay lit on auto procom ml 300 blue flame
If you have an ML300HGA, it is a manual-control heater, which means you turn it on and you turn it off. No thermostat. It does not have an AUTO setting.
Likewise, the thermostat-controlled models do not have a Manual mode. If you have the ML300TBA, it has a thermostat and will turn itself on/off in order to maintain a room temperature.
On manual models, the numbers (if any) on the dial are heat output selections. Set the control to the highest heat setting and that's what it does until you turn it off.
On automatic thermostat models, the numbers on the dial are temperature selections. Set the control to the highest heat setting and the heater will continue running until it is 85-90 degrees, then shut off. Set it around 2 and it will maintain a temp of around 70 degrees.
All Procom heaters are either automatic (thermostat-controlled) or Manual. None are both.
Oct 05, 2008 | Procom ML300HGA Heater
Water coming out freezer door
Replace the defrost heater thermostat in back of freezer wall.You can reach it from the open front freezer area.Just take loose the back wall plate(s).Youll see it (maybe under alot of ice)clipped onto heater coil.You should be ok now. Please leave a rating!!
Jun 07, 2008 | Refrigerators
Williams wall non-elec gas heater. Black copper wire tagged thermostat?
First make sure this is a heater set up for a remote mounted thermostat. If so, the gas valve has 3 screws labeled TH (thermostat) and TP (thermopile) that's the flame sensor with 2 wires coming off it, I don't know where the goofy name comes from. there will be one screw that has both, usually the top one. Wire accordingly. The new valves have a solenoid on the bottom. this connects to the high temp. sensor up top. It has 2 wires on it, one connects to the thermostat wire, the other goes to the screw with TH and TP. Or you can skip it and connect the wire from the back of the valve to the Th and TP screw. Make sure the thermostat wires aren't pinched somewhere, thus eliminating the thermostats control.
Feb 23, 2008 | Heating & Cooling
Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Nov 24, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
85 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
