Question about Casio FX-9750GPlus Calculator
I need to know how to set the Casio fx-9750ga plus calculator to calculate answers in degrees
    President:
  • 1,126 Answers
Page 14 in Chapter 1 listed here.
http://support.casio.com/pdf/004/fx_plus_chapter01.pdf
Posted on Sep 24, 2009
Matrix casio fx9750giihow can I find eigenvalues and eiginvectors for a matrix in my calculator? :)
This calculator cannot find eigenvalues and eigenvectors of matrices for you. The calculator does have many row and column operation that you can use to solve your problem. You need to know the theory of matrices, determinants, and some eigenvalue and eigenvector finding algorithms.
Dec 13, 2013 | Office Equipment & Supplies
I have a casio fx-9750GA PLUS. how do you do standard deviation with a set of numbers?.
Here are the capabilities of the calculator.
In stat enter the values in List1 and the frequencies in List2
Press the key corresponding to the CALC tab
Press the 1-var tab and you get the results as seen on the screen with title 1-variable.
Other screens show some two-varaible stats or regressions.
Jun 01, 2011 | Casio FX9750GII Graphic Calculator
I'm trying to graph in radians on a casio fx-9750ga plus, but it doesn't show up on my screen. what should i do?
To get results in radians you must configure the angle unit to be degree.
  1. In Run screen press [SHIFT][MENU] to access (SETUP).
  2. Use Down arrow to highlight the line Angle :
  3. Press F2 key to select the TAB Radian.
  4. Once you do that all values (input of trigonometric functions and polar graph functions OR output of inverse trigonometric functions) are in radians.
If your function is periodic (and all trigonometric functions are) set the window dimensions Xmin
= negative (2 or 3)P and Xmax) = (2 or 3) PI. Adjust if necessary to a smaller domain.
Sep 09, 2010 | Casio FX-9750GPlus Calculator
Degree and radian function Casio fx-9750GA Plus
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
May 06, 2010 | Casio FX-9750GPlus Calculator
Erasing coordinates in STAT
  1. Open the lists for display (or editing)
  2. Use arrows to highlight the value you want to eliminate.
  3. Press [F6:|=>] to display the rest of the menu TABS.
  4. Press [F3:DEL] to delete the highlighted value, or [F4:DEL-A] to erase all contents of the list where highlight resides.
  5. After you erase an X-value, erase the corresponding Y-value, otherwise you will have a dimension mismatch error.
Nov 10, 2009 | Casio FX-9860G Graphic Calculator
Factorial abbrevation on casio fx-9750GA PLUS can't find it!!!!
There is no direct or shifted keystroke for nCr nPr and ! on casio long ago.
You can access to those function using OPTN button; here is how to do...
press OPTN, F6(>), F3(PROB), F3(nCr)
Jun 13, 2009 | Casio FX-300MS Calculator
Log function on casio fx-9750GA Plus
Look it's simple in the calculator the default base is 10 so when you input log 3 its log 3 base 10 so:
maybe you know in math log x base y = log x / log y . So if you need log 3 base 3 its => log 3 / log 3 (by the way its 1)
Mar 27, 2009 | Casio FX-300MS Calculator
Casio fx-9750GA can't find Ran or Int
Turn calculator on. Select [RUN] [EXE].
In run screen press [OPTN] [F6:-->] [F4:NUM] then select the function you want to use. You have ABS, Int, Frac, Rnd, Intg.
Hope it helps.
Feb 15, 2009 | Casio CFX-9850G Plus Calculator
Casio FX-9750GPlus Calculator Logo
457 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
