Question about Sony KV-27S36 27" TV
I have a Sony KV-27S36 purchased mid to late 90's. I suddenly have sound but no picture. At first, I could get a picture by turning it off and on and letting it warm up, now I cannot even do that. Before the picture went out, it would "bunch up" at the top of the screen with squiggly black lines. I have read elsewhere that I might have to re solder the vertical ic chip to get the picture back. Does this sound right, and if so, how do I find this chip?
    Problem Solver:
  • 15 Answers
Yap! That sound vertical problem! just solder all old parts in vertical section and check yoke if have mold? Check all looking old's electrolytic capacitors and change that if nothing happened tha'ts the time to change vertical IC.
Posted on Feb 14, 2010
Know picture on screen but sound
check the line power transistor near the line transformer
make sure that a 90-115 volts is reaching a transformer, oscillation is not there.
Feb 20, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV-24FV12 picture problem
Alright, TV has hardware problem in Horizontal section and I would suggest to set Picture Quality as Soft Mode.
Jun 20, 2008 | Sony KV-24FV12 24" TV
Panasonic 42" Projection TV
See This Link
or read below:
This sounds more like a vertical deflection fault rather than a horizontal fault. I have my doubts has anything to do with the flyback, unless it is one of the supply voltages from that section.
Most of the common failures in your model series for this type of fault are many of the electrolytic caps and cold solder connections to the output devices since they run very hot.
Use a heat gun and circuit freeze to troubleshoot for the fault. Heat the caps in the vertical deflection area, and then test them with an ESR meter. You can then use the circuit freeze to test the questionable caps in the cold state after you find them to be failing from heat.
JANA
Jan 27, 2008 | Sony KV-27S36 27" TV
Picture and sound went out suddenly on a Sony KV-35S40
sony has problem with bad picture tubes as well as flyback transformers .if you have shorted hori output then replace it if set shorts it out again your looking at bad flyback transformer as well as maybe leaky tube.
Oct 27, 2007 | Sony KV-35S40 TV
Sony KV-32S36 32" suddenly stopped working, no picture or sound
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
Oct 27, 2007 | Sony KV-32S36 32" TV
Sony36xbr400hdtv
Hi there, please change the Flyback transformer. Best regards, Arpi
Jun 16, 2007 | Sony KV-36XBR400 36" TV
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
Apr 07, 2007 | Sony KV-27FV16 TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Televison & Video Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
