Question about Viper Security and Remote Start System (basic install included)
2006 Trailblazer & Viper 5301 with XK01, No heat or AC when remote started, where should the orange Accessory wire be connected to at the ignition. The ignition accessory wires are suppose to be orange1 and brown2, neither one of these connected to the viper allow my heat or ac / fan to come on with remote start.
  • 3 more comments
  • richn3 Sep 24, 2009
    Yes I installed myself, so if I go orange to brown I should look like this?
    H3-1 PINK Ignition 1 input/output PINK@IGN HARNESS
    H3-2 RED/WHITE Ignition 2 input RED/WHITE@IGN HARNESS
    H3-3 ORANGE Accessory output BROWN IGN HARNESS
    H3-4 VIOLET Starter output YELLOW@IGN HARNESS
    H3-5 RED Ignition 1 RED@IGN HARNESS
    H3-6 PINK/WHITE Ignition 2 output WHITE@IGN HARNESS
    H3-7 PINK/BLACK Flew Relay input N/A
    H3-8 RED/BLACK Fused accessory/starter input N/A
    ok ill check, I used T-Taps for temporary installation so that I know it all works then was going to splice and solder.
    Full list of hook ups I used.
    H1-1 RED/WHITE Trunk release output XK01
    H1-2 RED 12v constant RED IGN HARNESS
    H1-3 BROWN Horn output BLK/YLW IGN HARNESS
    H1-4 WHITE/BR Light flash isolation wire N/A
    H1-5 BLACK Chassis ground GROUND CHASSIS
    H1-6 VIOLET Door trigger input XK01
    H1-7 BLUE Factory horn input N/A
    H1-8 GREEN Door trigger input N/A
    H1-9 BLK/WHT Dome light output XK01
    H1-10 WHITE/BLUE Turbo timer input N/A
    H1-11 WHITE Parking light output BLK/GRAY @ SWITCH (-)
    H1-12 ORANGE Ground when armed output N/A
    H2-1 LT GRN/BLACK Factory alarm disarm output XK01
    H2-2 LT GRN/WHITE Factory alarm arm output XK01
    H2-3 WHITE/VIOLET Aux 1 N/A
    H2-4 VIOLET/BLACK Aux 2 N/A
    H2-5 WHITE/BLACK Aux 3 N/A
    H2-6 LT BLUE 2nd unlock output N/A
    H2-7 GRAY/BLACK Diesel start input N/A
    H3-3 ORANGE Accessory output ORANGE/BROWN IGN HARNESS (There is no Orange/Brown, You say Brown)
    1 BLACK/WHITE Neutral safety switch GROUND @ CHASSIS
    2 VIOLET/WHITE Tachometer WHITE @ CLUSTER
    3 BROWN Break shutdown input WHITE @ PRK SWITCH
    4 GRAY Hood pin switch VIPER SWITCH
    5 BLUE/WHITE 2nd rear defogger N/A
    1 BLUE Lock/unlock output XK01
    2 EMPTY Not used N/A
    3 GREEN Lock/unlock output XK01
    Yeah, just the brown wire is not fixing my problem. I get a check engine light now with about 10 codes when I remote start. If I clear the codes and start with key no problem, start with remote, engine light back on. I assume this is accessory related because what needs to be powering up is not. Both the orange and brown accessory wires show good voltage after the T-Taps, something else is messed up.. besides just the blower not coming on.... sigh... haha
    im just reviewing... i think maybe who posted the specs I used might of mixed up something..
    Coming from the Viper this is how it reads...
    H3 - 1 Pink - Ignition 1 output (also ignition input)
    H3 - 2 Red/WHite 12v+ Fused 30a input (contact 87 of RS Flex Relay)
    H3 - 3 Orange Accessory output
    H3 - 4 Violet Starter output (car side of starter)
    H3 - 5 Red 12v+ constant fused 30a input (for ignition 1 relay)
    H3 - 6 Pink / White Flex Relay Output (default is ignition 2)
    H3 - 7 Pink/Black Flex Relay contact 87a (default is ignition 2)
    H3 - 8 Red / Black 12+ fused 30a input (for accessory and starter relays)
    With some rethinking maybe it needs to be like this:
    H3-1 PINK Ignition 1 - PINK@IGN HARNESS
    H3-2 RED/WHITE Ignition 2 - RED/WHITE@IGN HARNESS
    H3-3 ORANGE Accessory - ORANGE IGN HARNESS
    H3-4 VIOLET Starter - YELLOW@IGN HARNESS
  • 15,935 Answers
The brown should be the one you use (secondary accessory)
The fan/ac selection must be made by you via the temp control knobs.
If they are set to off - the fans wont just come on... they have to be selected ON, and to the desired temperature.
The alarm simply provides the 12V signal to the relay allowing power to the accessories.
Did you install this yourself?
Is the secondary ignition wired up too??
There could be other problems associated with the fans not coming on as well... electrical troubleshooting is difficult without actually being IN the vehicle.
Your local DEI dealer should be able to sniff out the problem in no time, and get you running for under $35.
Thanks for using FixYA!!
Posted on Sep 24, 2009
  • 6 more comments
  • blueextc3221
    blueextc3221 Sep 24, 2009
    That looks like its a good install.
    Are you using T Taps or splicing/soldering the wires?
    Double check all the voltages after the taps if you are using them. Sometimes the insulation isnt cut through - or the male connector doesnt seat correctly on the tap.
  • blueextc3221
    One thing you havent listed is your Constant 12V red.
    Oversight?
  • blueextc3221
    From here - it looks good.
    Check the pulses and voltages after the brain to be sure the signal is being sent... and there isnt a problem with the taps.
    Check for the proper voltages before AND after the tap.
    Thanks
  • blueextc3221
    let me see if i can pull the wiring schematic for the vehicle.
  • blueextc3221
    here you go
    Audio/Mobile Video
    WIRE COLOR POLARITY LOCATION
    Battery ORANGE (+) RADIO HARNESS
    Accesory ORANGE (DATA) RADIO HARNESS
    THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON IS CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
    Ground BLACK/WHITE (-) RADIO HARNESS
    LF Speaker (+) TAN
    THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
    LF Speaker (-) GRAY
    RF Speaker (+) LIGHT GREEN
    THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
    RF Speaker (-) DARK GREEN
    LR Speaker (+) BROWN
    LR Speaker (-) YELLOW
    RR Speaker (+) DARK BLUE
    RR Speaker (-) LIGHT BLUE
    Steering Cntrls OPTIONAL
    THIS VEHICLE MAY BE EQUIPPED WITH ONSTARâ® AND MAY LOSE DOOR CHIME AND OTHER VEHICLE MONITORING FUNCTIONS WHEN OEM RADIO IS REPLACED. USE PROPER INTEGRATION PIECE TO MAINTAIN THESE FEATURES.
    Speed Cntrl OPTIONAL
    Radio Security YES
    Security
    Battery RED OR RED/WHITE (+) AT IGNITION SWITCH HARNESS
    Ignition 1 PINK (+) AT IGNITION SWITCH HARNESS
    Starter 1 YELLOW (+) AT IGNITION SWITCH HARNESS
    All Door Trigger GRAY/BLACK (-) IN HARNESS IN DRIVERS SIDE WINDSHIELD PILLAR
    TO AVOID THE DOMELIGHT DELAY FUNCTION, USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE,
    Domelight Super GRAY/BLACK (-) IN HARNESS AT VEHICLE LIGHT SWITCH
    LF Latch GRAY/BLACK (-) IN THE DRIVERS DOOR
    RF Latch BLACK/WHITE (-) IN THE PASSENGERS DOOR
    LR Latch LIGHT BLUE/BLACK (-) IN THE PASSENGERS DOOR
    RR Latch LIGHT GREEN/BLACK (-) IN THE PASSENGERS DOOR
    Trunk Trigger PINK/BLACK (-) AT MODULE IN REAR HATCH
    VIOLET (-) WILL MONITOR THE GLASS AT THE MODULE IN THE REAR HATCH
    Hood Trigger PINK/BLACK (-) ON LEFT INNER FENDER
    NOT ON ALL MODELS
    Alarm Disarm LT. GREEN (-) IN DRIVERS DOOR AT MODULE
    Parking Lights GREY/BLACK (-) AT SWITCH
    OR BCM TAN PLUG PIN E5
    Low Crr Pk Lights GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH HARNESS
    Data Bus VIOLET (-) AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
    Convenience
    Headlights-Lo WHITE (+) IGNITION SWITCH HARNESS
    LF Pk Lt Bulb BROWN (+) AT FRONT LEFT PARKING LAMP
    RF Pk Lt Bulb BROWN (+) AT FRONT RIGHT PARKING LAMP
    LR Pk Lt Bulb BROWN (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
    RR Pk Lt Bulb BROWN/WHITE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
    All Hazrd Lights WHITE (-) AT VEHILCE HAZARD SWITCH
    LF Hazrd Bulb LIGHT BLUE (+) AT FRONT LEFT TURN LAMP
    RF Hazrd Bulb DARK BLUE (+) AT FRONT RIGHT TURN LAMP
    LR Hazrd Bulb LIGHT BLUE (+) AT REAR LEFT TAIL LIGHT ASSEMBLY
    RR Hazrd Bulb DARK BLUE (+) AT REAR RIGHT TAIL LIGHT ASSEMBLY
    Wipers-Lo PINK (+) AT VEHICLE WIPER CONTROL SWITCH
    Wipers-Hi DARK BLUE (-) AT VEHICLE WIPER CONTROL SWITCH
    Parking Brake LIGHT BLUE (-) AT VEHICLE PARKING BRAKE SWITCH
    Seat Mem 1 WHITE (+) AT MODULE IN DRIVER DOOR
    Seat Mem 2 VIOLET (+) AT MODULE IN DRIVER DOOR
    Remote Start
    Ignition 2 WHITE (+) AT IGNITION SWITCH HARNESS
    Accessory 1 ORANGE (+) AT IGNITION SWITCH HARNESS
    Accessory 2 BROWN (+) AT IGNITION SWITCH HARNESS
    Anti-Theft Type GM PASSLOCK IIâ® ANTI-THEFT SYSTEM
    Anti-Theft Descript PASSLOCK II
    Key Sense LIGHT GREEN (-) AT THE STEERING COLUMN HARNESS
    Tachometer UNCOMMON COLOR (AC) ANY FUEL INJECTOR NOT PINK
    Speed Sense DK. GREEN/WHITE (AC) AT RADIO 24 PIN GREY PLUG
    OR PCM BLUE CONN. PIN 21
    Low Crr. Pk Lights GRAY/BLACK (-) AT VEHICLE LIGHT SWITCH HARNESS
    Brake Lights WHITE (-) AT BRAKE SWITCH ABOVE BRAKE PEDAL
    Reverse Lights GRAY (+) IN HARNESS IN DRIVERS KICKPANEL
    Horn BLACK (-) BCM TAN CONN. PIN E12
    ALSO BLACK (-) AT BCM MODUEL UNDER REAR LEFT SEAT
    Modules
    WIRE LOCATION
    Module 1 BCM-ATTACHED TO THE REAR FUSE BLOCK, BENEATH THE LEFT REAR SEAT
    Module 2 ECM-NEAR THE LOWER LEFT FRONT OF THE ENGINE
    Module 3 PCM-MOUNTED TO THE UPPER LEFT OF THE ENGINE
    Module 4 EBCM- FRONT DRIVER SIDE FRAME RAIL
    Doorlocks/Windows
    Databus Wire VIOLET (-) AT PIN 2 OF THE DIAGNOSTIC CONNECTOR UNDER THE DRIVERS SIDE DASH
    Power Unlock DATA BUSS SYSTEM (REV) AT MOTOR IN DOORS
    THE DOOR LOCKS IN THIS VEHICLE ARE MULTIPLEXED. WIRE AS A REVERSING POLARITY SYSTEM IN EACH FRONT DOOR OR ACQUIRE A MULTIPLEX INTERFACE ADAPTER FROM A SECURITY MANUFACTURER.
    PowerLock DATA BUSS SYSTEM (REV) AT MOTOR IN DOORS
    Driver Mtr Unlock TAN (REV) AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B2
    Driver Mtr Lock GREY (REV) AT THE DRIVERS DOOR MODULE IN THE DRIVERS DOOR 24 PIN CONNECTOR PIN B3
    Pas Mtr Unlock TAN (REV) AT MOTOR IN DOOR
    Pas Mtr Lock GREY (REV) AT MOTOR IN DOOR
    LF Window Up DARK BLUE (REV) DRIVER DOOR MODULE
    LF Window Dn BROWN (REV) DRIVER DOOR MODULE
    RF Window Up LIGHT BLUE (REV) PASSENGER DOOR MODULE
    RF Window Dn TAN (REV) PASSENGER DOOR MODULE
    LR Window Up DARK BLUE (REV) REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
    LR Window Dn BROWN (REV) REAR LEFT WINDOW SWITCH IN REAR LEFT DOOR
    RR Window Up DARK BLUE (REV) REAR RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
    RR Window Dn BROWN (REV) RERA RIGHT WINDOW SWITCH IN REAR RIGHT DOOR
  • blueextc3221
    One thing i have found going thru your hookup is the secondary ignition wire - you have listed as red/white
    It should be white only.
    Red/White is a second constant 12V feed.
  • blueextc3221
    unfortunately i cannot find the VEHICLE wiring schematic anywhere to verify the blower activates from the accessory, or secondary accessory trigger.
  • blueextc3221
    looks good
I have a viper 5706v remote start/security alarm on my 2007 honda accord sedan. When I remote start my car no inside lights, ac/heat unit, or the radio comes on. Just the engine is running.
the accessory 1 and or 2 wires from alarm brain are most likely loose or not connected at all to the accessory wires on the ignition side... hence the lights and accessories not coming on but engine does...
if you installed it I would recheck those wires... if a shop installed it I would take it back to them...
Jun 28, 2016 | Viper Vehicle Parts & Accessories
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
I had a 5301 installed this week in a 07 Nissan Pathfinder. Everything seems to work fine except that when the vehicle starts the heater & fan does not come on. Did the installer miss a...
Sounds like the tech didnt hook up to the heater acc. wire located at the ignition cylinder. The color of the wire in the car is green\ yellow tracer.... Color of the wire from remotestart is orange. So find where the orange wire from the starter is and hook it up to the green\ yellow wire.
Jan 07, 2011 | 5301 Responder LE 2Way Remote Start and...
Just go viper remote start put in yesterday. started truck this morning fine with it, but when got into car no heat was on. as soon as i put the key in and turned it to ignition, heat came out. any ideas...
The problem is that the tech who installed it didn't go to the heater accessory wire. This is a wire at the steering column that controls the power going to the heater to turn itself on.
Dec 14, 2010 | Remote Start System
Heat or A/C does not turn on when car is remote started. As soon as you put the key in and turn it to the on pos. the heat or A/C comes on
You did not mention the year/make/model but, it sounds like the HVAC wire of the vehicle was not connected during the installation or, the 30 amp fuse that powers the accessory output from the Viper is blown. Did the heat and A/C work before during remote start?
Nov 29, 2010 | Remote Start System
Getting Viper 5301 to turn on heat fans in 2005 Mruano
Most likely only one of the cars 2 accessory circuits was powered up by the remote start. There definitely are 2 (red and white/blue). Please double check with multi-meter before just hooking up. But that should solve the no fan upon remote start.
Jan 29, 2010 | Remote Start System
VIper 5301 with XK01 on 2006 Trailblazer.
My I ask what the problem is. I am more than willing to help if I get a little more info on your problem.
Sep 23, 2009 | Car Audio & Video
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
245 people viewed this question
Top Viper Home Security Experts
Kevin Daniels
squeely
Are you a Viper Home Security Expert? Answer questions, earn points and help others
