Question about Cell Phones
I put in a security code to lack my phone now I can't get it off it keeps going to lock mode how can I unlock my phine so it won't do it unless I activate it?
Locked out of my phone with security code. Need help to get it open without loosing all my babies photos,videos and numbers, Not too worried about numbers just videos and pictures 917 363-3137
the security code you want and I am guessing here because of the lack of exact detail is the PUK code
That PUK code only comes fro a service provider
call them on another phone provide proof that you own your account and they will give it to you
put the code in the phone then your pin number and if that is the problem then it will open with all intact
Jan 04, 2016 | Samsung I5500 Galaxy 5 Unlocked Android...
NEC DT700 phone lock
just lift the handset and put password. 0000 is default password.
Aug 14, 2012 | NEC DT330 - - Phone
Unlock code
What is Mobile Phone brand and Model?You can use the unlock code to unlock it from network lock.You can buy the Unlock code from Mobileunlocksolutions.com and Unlock it easily.
May 23, 2012 | Cell Phones
I can't change my security code hw can i change it ? it is 12345 the dafualt one , and i want to change it how ?
I suggest you leave the security code alone, it is used to clear the phone call logs etc.
I recommend to put a pin code on the SIM card to lock your phone's keyboard. When you open your phone or unlock the keypad to access the phone's menu etc. then you need to enter the 4 digit pin code. This also prevents anyone accessing your phone unless they have this pin code.
Sep 09, 2011 | Nokia Classic 2700 Cell Phone
Putting a lock code on an e71 to unlock phone
It is possible to put code on E71, You go to settings then security, you will enable the keypad security code and enable your phone code also. With these nobody can access your phone without asking for security code. Take note Phone, sim and keypad pin code must be enable. Thanks
May 13, 2010 | Nokia E71 Smartphone
LG260 Rumor cellular phone unlock code forgotten. Is there a reset code?
you could probobly just take off the battery and then put it on and turn the phine back on, it might work if you dont have the phone locked on power up. this is only a suggestion. otherwise you can call your sprint store or check online and maybe find it there? i hope this helps!
Sep 27, 2009 | LG RUMOR Cellular Phone
I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
Apr 15, 2009 | Nokia 6300 Cellular Phone
FORMAT CODE FOR MOTOROLA L6
my motorola l6 is keep on restarting when ever i press a key so i thought it might get better to reformat my phone so i need the format code for it.
Mar 23, 2009 | Motorola Mobility L6 Cellular Phone
My Nokia 5310 XpressMusic is locked on standby mode
tr.y and use the default codes 0000,1234,9999 this should unlock it
Sep 14, 2008 | Cell Phones
Motorola L7
There are two codes for the security of the MOTOROLA L6, the unlock code which is usually 4 digits and is set originally to '1234' and the security code which is 6 digits and set at the factory to '000000'. These codes are the same across the world unless a specific service provider decides to change them.
• To change the unlock code, you can go to NEW PASSWORDS by going to the SECURITY option in the SETTINGS menu. The phone will prompt you to enter UNLOCK code, Put in '1234' or the last 4 digits of your phone number and if both don't work, try the security code 6 digit number.
• If you lose the other codes like SIM PIN code, PIN2 code, cell barring password and even the SECURITY CODE, these can be reset by only the service provider.
• You can prevent others from misusing your phone locking it when not in use. This is achieved by selecting LOCK NOW in the PHONE LOCK options in the SECURITY menu
• Choosing AUTOMATIC LOCK to ON in the PHONE LOCK menu will lock the phone automatically whenever it is turned off.
• A locked phone can receive phone calls but will need to be unlocked using the code to be answered
• There is also a simple way to prevent accidental pressing of keys by locking the key pad using the main menu soft key followed by the '*' key in quick succession.
Nov 17, 2007 | Motorola Mobility L6 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
