Question about Proform Exercise & Fitness
Profrm petl3013 electric going through but will not start. if i press start then stop, and start again it will move just one inch
How to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Aug 04, 2014 | Stanley 77-720 Stud Sensor 200
2003 Nissan pathfinder sunroof problem
I would check the power at connector to motor, if ok replace switch.
Jul 22, 2013 | Nissan Pathfinder Cars & Trucks
1997 Sable Driver Seat Only Moves 2 Inches At A Time
Could be the switch, but it sounds like the motor is going bad. However, I dont know if you tried to lubricating the tracs. Some of these seats are on ball bearings and some on nylon bushings, either way they need to be lubricated once in a great while. Have you tried to help the seat to move by pushing in the direction it is going to see if it speeds up. If so, the seat motor is going out or the tracks are binding up. I hope this helps.
Apr 02, 2013 | Ford Taurus Cars & Trucks
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Automatic sliding doors
My door also had the same problem: It would only open a few inches, then it would stop. Moving it manually one more inch and trying again would make it go all the way. In my case, this was due to the wire harness being bent in a certain way right at that point (and the wires being broken there).
First make sure that the door moves smoothly over the location where it stops by moving it manually. If it's hung up on something, try to find it. In my case the door itself moves very smoothly all along the path with just a finger (or two) pushing it.
I took two screws off the top plate of the arm where the motor in the door meets the frame (bottom of door). I then took this plastic arm cover off. I could then see the wire harness and the gear. Now, make sure there's nothing major wrapped around the gear; next, see if you can get the door to start moving by pressing the button at the same time as you wiggle the wire harness. If the door starts to go, then it's likely a bad wireing harness.
I took the wiring harness out of the arm and moved it below the arm instead of within it. Now it works just fine (the harness doesn't bend in the same bad way anymore). However, I anticipate having to buy a new wiring harness to fix it for good.
Jun 29, 2009 | 2007 Dodge Grand Caravan SXT Minivan
Scanner Faliure
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
8011
Jan 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Need instructions for setting a Sharp watch model # 2092
All the settings seem to go through the start/stop button. If you hold it down for 3 (not 2, not 4, but 3) seconds, it toggles in and out of "set the watch mode". You can tell you are in it because the seconds at the bottom go all blinky. Use (quick press) start/stop to move from seconds, to minutes, to hours, to year, to month, to day. Mode subtracts, reset adds. To set alarms, etc, first put the watch into Alarm Mode (Mode button, again).
Use the reset button to move to the selected alarm (1-5).
Hold the start/stop button for 3 seconds to toggle into "set the alarm mode".
Quick press of start/stop moves between things to set (kind of alarm, hours, minutes).
3 second hold of start/stop takes you out of setting mode.
Jan 05, 2009 | Sharp Stainless Steel Code Ii Analog...
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Exercise & Fitness Logo
98 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
