Question about Sony Ericsson Cyber-shot C902 Cellular Phone
Flcikering screen on C902
My C902 has a flickering screen. its been 4 days since i bought it. the screen flickers, increase decrease in screen brightness, no matter which application i am using
Increase in brightness & sometimes switch to "negative" momentarily
he Dell I'm using also has an adaptive brightness, regardless of the fact it does not have a light sensor. It just changes brightness of the screen depending on how much white/black is shown at that moment. Whenever I switch from a very dark to a very bright website I notice and increase/decrease in screen brightness. I'm running Windows 7 by the way.
Good Luck
Jan 01, 2018 | Samsung SyncMaster 2333SW 23" LCD Monitor
I bought new screen of ebay but it flickers
Did you check both ends of the LCD Screen cable? The end that goes behind the lcd screen at the top and also the other end that attaches on the board. Also put a piece of tap over where the connections meet on the lcd screen to keep it in place.
Did you reseat (unplug then plug back in) the 2 cables that are in the LCD Inverter located at the bottom of the LCD Screen?
Apr 02, 2012 | Samsung R519-53S Notebook
My monitor compaq model MV520 is always blinking every time I open my computer, How can I fix it?.
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to answer and solve your problem. Your Compaq MV520 Monitor is always blinking every time you turn on your computer and you want to know how you can fix it? First, we need to troubleshoot the problem. I'm thinking you probably need to refresh the flicker rate on your monitor. The flicker rate is probably set on a low setting, which is causing you screen to blink (flicker). This can be bad for your health as well because it can cause eyestrain and headaches. Your monitor is a CRT (Cathode-Ray Tube) model. These types of monitors can cause a lot of screen flickering. Now that we've troubleshooted the problem, now it's time to solve the problem. There are two ways you can solve this problem. You can either refresh the flicker rate or you can buy an LCD monitor. LCD monitors flicker-free. My suggestion is that you refresh the screen flicker rate. To refresh the flicker rate, go into your System Preferences or Control Panel, click your operating system's appearance and display link and click your screen adjustment link. You may have to click your advanced settings link. Click your monitor tab and from there adjust you screen refresh rate. You may have to adjust your screen resolution before you refresh the screen rate. If you have to do this, make sure the screen resolution you choose supports you monitor's height and width as well as visibility. The higher the resolution, the higher the screen rate. The instructions I'm giving you may sound like this because I'm not sure what your operating system is. I'm not to familiar with Mac Operating Systems, but if you have a Windows Operating System and you need better detailed instructions, just reply back. I hope this decreases your screen flickering and gives you a better viewing experience.
Jul 07, 2011 | Computers & Internet
. I bought an Amcor AWS090HR a couple of years ago
?Call pridiom group 201-266-8234 option 2 for warranty and service
?*Self Diagnosis Functions*
Our company provides the thoughtful services for customer,air conditioners had been
installed self diagnosis system to display the information for the units.
INSTALLATION & REPAIR GUIDE
Split Wall-Mounted air conditioner
8
*According to the service conditions and operating environment , the inside of the air conditioner
will become dirty after several seasons (3 to 5years ) of service , resulting in decreased operating
performance .Inspection and maintenance are recommended in addition to usual cleaning (The
air conditioner can be used for a longer period and without anxiety .)
*As to inspection and maintenance , consult your dealer or any one of business offices of dealing
companies .(Service charge is required in this case .)
*We recommend to perform inspection and maintenance during an off seasons.
*Choose the place where hot air and operation noise from the outlet of the outdoor unit do not annoy
the neighborhood .
*Things left near the outlet and inlet of the outdoor unit cause malfunction or increased operation
noise . Do not leave obstacles near the outlet and inlet .
*If irregular sound is heard during operation , consult with your distributor .
*Inspection and Maintenance
Note:Above self check information is commonly applicable in our most air conditioners,but some
are special,you can refer to the User's Manual for information or contact the dealer or authorized
maintenance people for help.
Digital self-check code/
(Polychrome screen self-check code)
Hint to defrosting Flicker 1 time/1s
Hint to defense
against cold wind Flicker 1 time/3s
Failure of room
temperature sensor
Failure of coiled
pipe sensor
Abnormality of
outdoor unit
Without feedback of
internal fan motor
Zero crossing signal
without current
External feedback
failure
Overheat protection
Water pump failure
Self-check code of luminotron/
(Self-check code of running lamp)
Flicker 2 times/4s
(Flicker 2 times/8s)
Flicker 3 times/5s
(Flicker 1 time/8s)
Flicker 4 times/6s
(luminating)
Flicker 5 times/7s
(Flicker 6 times/8s)
Flicker 6 times/8s
Flicker 7 times/9s
Flicker 8 times/10s
Flicker 9 times/11s
Self-check
information
Indicates "dF"or defrosting
indicator displays
Fan motor picture not running
E2/(L2)
E3/(L1)
E4/(E5)
E5/(L6)
E7
E6
E8
E9
Nov 30, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
LCD flickering at the bottom of screen
This appears to be a faulty CCFL lamp which supplies the back-light.
Because it is less than 6 months old, I suggest you get it fixed under warranty.
If you try to fix it yourself you will void your warranty.
Feb 12, 2010 | Toshiba Satellite M305-S4826 Laptop
Font size much too big on the screen
By "font", do you mean everything is large on the screen, including icons, and menus?
If so, your screen resolution might be set very low.
To increase the resolution (and subsequently decrease the size of everything displayed)...
Windows XP
1.) Right-click on the desktop and choose "properties".
2.)Choose the "Setitngs" tab.
3.)Slide the "Screen Resolution" slider towards "more"(the right) and click "Apply"
4.)Your screen will flicker and test the new resolution. If you like what you see, Click "Ok". If you do not, or your screen remains black, you can wait 15 seconds, and your screen will revert to it's previous resolution.
Windows Vista
1.) Right-click on the desktop and choose "Personalize".
2.)Choose the "Display Settings"
3.)Slide the "Resolution" slider towards "high"(the right) and click "Apply"
Hope this helps.
Sep 19, 2009 | Acer Extensa 5620-4020 Notebook
I have an Envision Monitor G221 WK which has suddenly started flickering badly. Any suggesions?
Try the auto adjust button first.
Does increasing or decreasing the brightness affect the amount of flickering ?
Flickering is usually a inverter board or a backlight bulb issue. You would have to take it apart to try to tell.
If you do take it apart and if you can send me pictures of the boards to bammbamm@ptd.net. I may be able to see the problems if it has typical issues.
fran
Aug 12, 2009 | Envision Computers & Internet
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
79 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
