Question about Dewalt 12" Beveling Sliding Compound Miter Saw Dw718
I lost my manual and need to adjust the bevel settings
  • 67 Answers
Make sure its a compound mitre and not just a mitre saw. The check in the back for a round knob with degrees marks on it, theres your adjuster.
Posted on Sep 24, 2009
Is there a way to adjust the set pin to get a true 90 degree bevel?
set the blade at the built in 90 degree lock, now use a square and adjust the fence (usually two bolts visible on top of the fence) to the blade at 90 degrees....there are some shops which offer this service under a "tune-up" or calibration.
Jul 07, 2012 | Hitachi C12RSH 12" Sliding Compound Miter...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
My blade is not square to the table i,e if I make a 90deg cut, it is about 1/16 wider at the top of the board than it is at the bottom. I've lost my owners manual and was wowndereing holw I go about...
Set your saw square using a combination square if you have one. Then to to adjust the saw to stay square there should be a gold coloured nut that you can adjust on the right side below the lever you use to unlock the saw when setting what angles you want to cut. Either move it in or out to get the proper setting. Hopefully this answers your question.
Apr 25, 2011 | Makita 10" Dual Bevel Sliding Compound...
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
The bevel on my my ryobi 10" table saw model BTS12S does not change from the knob reguardless of the position of the bevel lock ar regaurdless if i adjust the bevel lock. i just got this saw so i do...
Suspect that a part was left out of the bevel adjust mechanism. Best to take the saw back and get a warranty replacement--let warranty fix the defect. Can you change the bevel of the blade by pushing/pulling the blade? I would suspect a missing worm gear on the bevel control shaft if you can. Otherwise, look for loose/missing set screws on the shaft or possibly a missing key. Good luck!
Oct 30, 2010 | Garden
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
I have purchased a dewalt 718, 12 inch sliding double bevel saw , private sale, saw was only used a couple of times and is in new condition .Checked cutting bevels and found that the left 45 degree does...
The fence may be getting in the way of the arm when you adjust the trunion assembly fully to one side or the other for bevel cutting. Adjusting the fence all the way out away from the trunion assy. should allow full 45deg adjustment. If this is not the case, it could be--even though its only slightly used--that there is sawdust built up enough in the housing to keep the arm from fully adjusting.
While the latch COULD indeed be faulty, it generally should always be tightened/locked so that the trunion assy. is fimly "locked" before cutting as this is designed to keep the saw from shifting mid cut, causing binding, uneven cuts, broken blades, seized bearings, etc.
Dec 02, 2009 | Dewalt Heavy - Duty 12" Double - Bevel...
DW705 Miter saw Spark in motor Compartment
Yes spark in motor compartment is normal. You only need to worry if you see a lot of sparks flying out of the motor compartment! Most power tools will spark inside the motor compartment (particularly if carbon brushes are used).
Bevel and miter could be off... Consult your manual for how to adjust these correctly, but usually the bevel has a 0-degree setting screw or adjustment, and the miter adjustment on the saw is usually done by altering the fence position... Again check your manual for specifics on your saw.
Mar 19, 2009 | Dewalt Saws
45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Nov 17, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Dewalt 12" Beveling Sliding Compound Miter Saw Dw718 Logo
619 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
