Question about Motorola Mobility Rival A455 Cell Phone
My sandisk when inserted does not recconize the music thatis on the card
How do i downloag music stored on a file in the computor to my card to put in my phone. I put the card in the computor and it dont tell how to use it
first insert your card to computer, use card reader your card will show as removable disk
if the card was show, open windows explorer, search music that you wan to download to card
select the music file that you want to insert to card
right at file that you select then click copy
after that go to removable disk drive, open it, open the folder music/sound
at that folder right click and click at paste
and you done the process download from computer to card
eject your card from your computer
insert your card to the phone and you canplay music at your phone
i hope this helpful
thank you for using fixya
Feb 07, 2011 | SanDisk 2GB microSD Memory Card
How do i record music to my phone
1) Copy the music files (.mp3, .ogg, .wmv) to the memory card into the music folder.
2) Insert the card in the phone.
3) If the files don't appear search for a refresh button into your music software or wait for a while.
Nov 04, 2010 | SanDisk 2GB microSD Memory Card
How do i download music frm my laptop to my sd
Insert the SD-card into a SD-slot in your computer, if your computer has such a slot. Then, Windows will assign a "drive-letter" (not 'A:' or 'C:' or 'D:', but you get the idea) to the storage-device.
Then, copy files from your C: drive-letter to the "new" drive-letter.
Or, if your SD-card fits into your portable music-player, and the music-player can connect to your computer with a special USB-cable, then insert the SD-card into the music-player, and connect the USB-cable, and turn the music-player on. Then, copy the files.
Apr 02, 2010 | SanDisk 2GB microSD Memory Card
Write protection
There is a small switch on the card. The Sandisk site has a photo of a larger card, smaller cards like the microSD must be inserted into the standard SD adapter.
Jul 16, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD not working on BBerry Curve
Two options--Go to Options > Media Card, set Auto Enable Mass Storage Mode When Connected to Yes.Another one go to this site http://forums.pinstack.com/f8/mass_storage_issues_heres_the_fix-96938 and on the first post there is a file "BB storage Activation new.rar" of size 3.63 Mb.Download it,extract it and upload it on your phone and just install.It will definitely solve your problems.Also you need to register there to download that file...just do it no problem.
Jun 01, 2009 | SanDisk 2GB microSD Memory Card
Trying to download music from pc to Sandisk
You should be able to stick the sandisk into your pc, provided your pc has a card reader. If not, the usb from the zuma (while the sandisk is inserted, of course) should work just fine.
Mar 14, 2009 | Gateway M305CRV Notebook
Microsd
when the card is inserted into your laptop it is just like another drive (like your c drive) simply drag and drop onto the icon for the card or double click on the card to open up a window then drag the files into it.. what are you planning to use the SD card with? in itself it is just a drive it can't do anything else it is just for storage... you can of course insert it into another device (like a music player with an SD slot) and play the music you have put onto it
Oct 27, 2008 | SanDisk 1GB microSD Memory Card
I got a SanDisk 3 in 1 SD card. I don't know how to get music off of my computer to the tiny SD card to my phone.
You can connect the SD card to the Card reader or insert the SD card to the SanDisk 3 and then connect the SanDisk 3 to the pc. ( U need the cd utilities and install software to the ROM )
I f your SD card is connected to the PC you can directly copy the music from the PC to the SD card. SD Drive is created by windows found in " My computer" same is through with the SanDisk 3 connected to the PC. you can directly copy the music files onto the sand disk.
Do not rate me if this not solve the sytem. notify if you need more solution. melnavz
Apr 08, 2008 | Computers & Internet
Cannot add music onto blackberry curve 8310 with sandisk 1 gb memory card
pls format the card from the blackberry device.
this should take care of the issue
Feb 27, 2008 | SanDisk Memory Media
Motorola Mobility Rival A455  Cell Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
