Question about Neff H5470N0GB Microwave Oven
Locating the mangatron fuse for a Neff H5470N0GB
Thanks to guru localwonder, I'm suspicious my mangatron fuse may be gone, but can't locate it having taken the main cover off and taken the control panel out. Do you know where it is?
  • 1 more comment
  • barrababa Sep 25, 2009
    Hi Bullgodchief.. Thanks again for your very helpful reply, will try all of the above. To answer your question, yes, the micowave looks like it's working, i.e. fan, light, timer etc. but it's not heating anything. However, after I try to operate is for say a minute or so, the inside of the oven is warm after opening the door.
  • barrababa Sep 28, 2009
  • 388 Answers
I have never heard of a "magnetron fuse". Fuses are easy to locate on microwaves, though. The easiest way is to follow the power cord from where it enters the oven's frame to where it terminates on the board. There is a fuse in the immediate vicinity of the termination. You can check the fuse with an ohmmeter...it should read zero ohms, anything else means the fuse is blown.
If your oven is blowing fuses that means there is something else wrong with it, most likely the magnetron. You can't miss the magnetron, it is mounted on the side of the cooking cavity, you can identify it by its heat fins. If you want you can trace the wires from the magnetron back to the board, there usually is no fuse in that line but a capacitor is always in that line. Check the capacitor as well, if reads zero ohms it is bad and it is what needs to be replaced.
I am curious as to what is going on with your oven. Do the lights and fans come on but it doesn't heat or is it completely dead, no lights, no display, nothing?
Either way, I am including a link for you to a site that has all the parts and accessories you need for your model microwave. I hope this helps, here is the link: http://www.espares.co.uk/parts/microwaves/neff/h5470n0gb%2f02/p/1095/1126/0/553422
Posted on Sep 24, 2009
Testimonial: "Thanks Bulldogchief.....very helpful indeed"
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Neff Master
  • 848 Answers
Locating the mangatron fuse for a Neff H5470N0GB? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
490421200100R QLIF 041 HP 790421200A00R Power Supply Backlight Inverter
Posted on Dec 11, 2014
Neff b6774N0gb/02. Inner glass shattered. replaced. Internal fuse blown. replaced. Now microwave working (heating water) for approx 5 sec, then switching off, beeping and showing E1 fault. Also display...
Usually if this model stops after approx 3 secs it is an invertor or mag fault. Check that the aerial cover is clean Page 3 of the breakdown part position 315. If this is really grubby it would be the cause of the door shattering. The PTC is not used on the microwave function so may be an additional fault. Check also the alignment of the door switches as this can also cause a similar fault. My best guess is if you remove the mag, you'll probably find scorching on it and it (and the invertor) will need replacing.
Mar 25, 2013 | Neff Microwave Ovens
My neff microwave 547 switches it'self off after 25 seconds
Any repair to a microwave should only be carried out by a competent engineer as even when the unit is unplugged there is potential for a large amount of voltage to be stored by the capacitor (which in the case of this model is part of the inverter board). I suggest that you bite the bullet on this one and organise a call from the manufacturer assigned repairer.
Sep 09, 2011 | Neff H5470N0GB Microwave Oven
Neff H 7871 microwave, 8 years old. Just gone dead. No lights. tried all the buttons and replaced fuse. Any ideas?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 15, 2011 | Neff H7871N2GB Convection / Microwave Oven
Kid put mom's curling iron in microwave. Turned it on and now nothing. No lights, nothing. Is there a fuse to check? Maybe it is too far gone? Thanks
there is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations
Jan 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
My h5470nogb/03 900 watt microwave cuts out after 20 seconds what is the problem please
Possibly the magnetron is not producing power and as the cavity temperature is not rising, it cuts out.
Is there an error code in the display?
Jan 02, 2011 | Neff H5470N0GB Microwave Oven
Neff microwave oven not heating
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 22, 2009 | Microwave Ovens
How do you turn the beep off?
Finally worked out how to do this today! I don't know what model you've got (I don't know what one I've got - it's built in and we've lost the manual) but try pressing the START button for six seconds. This should change the default from 30 beeps to 3 beeps. Bliss.
Apr 16, 2009 | Neff H5470N0GB Microwave Oven
H7881 Neff Microwave Light Bulb type
go to the NEFF spares area here: http://bshappliancecare.com/Neff/neffspares.html at BSHAppliancecare - if you an locate the FD or E-Nr inside the appliance door then you are laughing. The site's a doddle to use. It should have exploded diagrams and part numbers to look up - and order. The prices seem to be fantastic for the replacements I've made (oven and fridge seals)
Nov 15, 2008 | Microwave Ovens
Lost instruction manual as to how you reset time on clock
Go here to download to your manual:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 30, 2008 | Neff H5470 Microwave Oven
Neff microwave combination oven
no solution sorry but we also have a Neff mw/combi oven which keeps blowing for no apparent reason, the Neff repair man has looked at it 4 times and practically replaced every component -power module, operating module,relay board, door switches but it`s just gone again! The model is a H5972N0GB/01 and it is approx 3 yrs old, no problem for the first 2 years .Time to write to Neff -is yours the same model?
Apr 23, 2008 | Microwave Ovens
Neff H5470N0GB Microwave Oven Logo
660 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
