Question about Garden
Need to no wat 11/4 and 11/2 are for carburetors how muck do you tern in
Where can i buy a carb kit for 011avt stihl?
First you need to determine if you have a Zama C1S-S1C or the Walbro WT-29A carburetor. The Zama will need a RB-11 kit and Walbro will need a K10-WAT kit. These kits should through most online small engine parts sites or your local small engine repair parts store.
Here is one place I order parts from that has these kits.
Lawn Mower Parts
Oct 29, 2014 | Stihl Garden
Why dose my 1990 Toyota corolla engine tern over
check your fuel system and spark try throwing a little gas in the carburetor and see if it will start if not check for spark take out a plug and ground it turn over the engine there should be spark if it starts after throwing gas in the Carburetor its a problem with your fuel pump
Oct 02, 2014 | 1990 Toyota Corolla
What is the postcode for tern path glenrothes
Since I live in the United States I really don't know but a Google search came up with this.
Tern Path, Glenrothes Postcode KY7 6TN
KY7 6TN Postcode Information
Postcode for Tern Path is KY7 6TN
Town for Tern Path is Glenrothes
County for Tern Path is Fife
Longitude for Tern Path is -3.1802191
Latitude for Tern Path is 56.2145598
Morse code for KY7 6TN is Kilo Yankee Seven Six Tango November
Sep 16, 2014 | GPS
My homechoice food peicessor it does not wat to tern on,i was just trying to use it for the first time
I just bought one too having the same problem. Please advise me if you got a solution
Sep 30, 2012 | KitchenAid Food Processors
I have a f150 88 fuel In.and i wand to element the In. and make it a carburetor Wat can of intake i need? and from wat year? Thanks
That depends on your engine size and setup, however, edlebrock will have a aftermarket intake that will direct fit to your truck.
Jun 09, 2011 | 1988 Ford F 150
Mi grand 2000 check gages tern on wats hapening
one of the gages has to be in the danger zone check even gas gage
Feb 10, 2011 | 2000 Jeep Grand Cherokee
Starter terns but will not tern motor
Most motorcycles have an internal one-way clutch. It is in the oil and consists of several metal barrels that grab on to a smooth drum on the side of a large gear. If the smooth part of the drum becomes chattered the barrels will no longer grab so the starter spins, but the motor does not turn over. What you need is a one-way clutch and the starter gear it rubs against.
May 11, 2010 | Motorcycles
My xbox 360 wont turn on
ok this is wat im doing with my xbox i plug it in and it wont tern on
how do i fix it
Feb 22, 2009 | Microsoft Xbox 360 Console
Broken xbox 360
check if it is on the cords, or you might need to play with the wires by picking them up and things .....that is what i needed to do.... and I play it as long as it isis to the side....
Apr 27, 2008 | Microsoft Xbox 360 Console
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
