Question about Car Audio & Video
Car problem there is this signal showing in the car in dash ode meter and don't know what it is and car won't start because of that signal?
    Sergeant:
    Champion:
  • 231 Answers
Disconnect negative battery cable and retry ..but if car has car stereo and or other device that requires a code.make sure you have codes or they will not function if you dont have code..but if not you should be okay to disconnect battery cable to reset
Posted on Dec 16, 2007
Working on a 2005 Buick LaCrosse cxs with the 3.6l. Car won’t start. Won’t turn over or anything. Hooked tech 2 to it and it says fuel security disabled. Have master key. Tried reprogramming but it doesnt...
First make sure the battery is fully charged. Then check for clean battery post connections. Then check all the main fuses located in the plastic box under the hood close to the battery on top of the inner fender. You should have all dash lights if everything check out to this point and it should turn over with the key.
Aug 25, 2017 | Buick Cars & Trucks
Engine stalls when turn on headlights
You probably have a ground issue , looking at a wiring diagram or ground distribution diagram to see if these share a commom ground point or share power from same fuse,https://www.youtube.com/watch?v=WoN1nou5t1Q&t=224s circuit with a high resistance problem . Do you know how to test automotive electrical circuits with a DMM - digital multi-meter , how to read an use a wiring diagram to pin point test spots in a circuit . Free wiring diagrams at http://www.bbbind.com/free_tsb.html . Check out these videos on voltage drop testing an basic electrical testing . This is the way to find electrical problems .
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia YouTube
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
good luck !
Jul 30, 2017 | 2003 Chevrolet Silverado 1500
Put in new starter in 2003 ford expodition and it still won't start what can my problem be won't even turn over?
Smart lock? do you have a picture of a red hand on instrument panel? With falcons quite common. Turn & hold key @ start posision, Hit dash upwards on left side of steering colum, If start = faulty smart lock module. I don't know if expodition has smart lock but probably does
Jun 15, 2012 | 2003 Ford Expedition
2008 suzuki c50 have no dash or headlights and won't start
Usually all 3 of these things mentioned are activated when the key is turned to on. I don't know about any fuses or links on that bike but check your manual or online to locate them. The problem could be in the area of the start switch also.
Jun 14, 2012 | 2008 Suzuki Boulevard C50
Turn signals don't work
did you change the light bulb
Mar 13, 2012 | 1994 Mercury Sable
I hit a deer while on the highway, we only have liability, no comprehensive coverage, and it messed up my drivers side headlight & turn signal & a piece of the grill. My husband fixed the...
Hello! I don't see a connection between the headlight issue and not starting...However I definitely see a connection with the accident and not starting...When you say "not starting" do you mean the starter doesn't crank the engine or it does crank the engine but won't start? Do you have a meter and a wee bit of experience using one? If you do we can isolate this fault together...Send a comment...Guru...Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Sep 21, 2011 | 2000 Pontiac Montana
My turn signal won't lit when activate and my brake light also wont also but is illuminate. The Top Brake light do light up when but only when the lights are turned on manual setting if they are on...
possible multifunction switch gone bad for turn signal problem. do headlihgts come on in a dark setting on automatic or not? if they don't come on when it is dark then most likely bad light sensor in top of dash or maybe unplugged if recent dash work has been done.
Jul 13, 2011 | 2002 Mercury Mountaineer
My 2005 Saturn Ion won't start! I've had quite a
Body Control Motion device:
Common on thjis car call your dealer to see if they have a recall.
Good luck
Jun 23, 2011 | 2005 Saturn ION
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
