Question about Whirlpool Dryers
Takes 2 or 3 hours to dry -replaced heat element already
  • 3 Answers
Check venting in unit and exhaust vent to outside for air restriction or smashed vent
Posted on Sep 24, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My Maytag Dryer model DE308 takes 2 hours to dry a load of clothes. I have air flow, but after an hour, the clothes are still damp. THe dryer does not have the heat that it used to. I know that with the...
Good day,
Your right on the heating element.
If your positive the vent system to the outside is clean, then
Remove the front panel of the dryer, and inspect the blower wheel. If worn on the shaft(slipping), it needs replaced.
2. Remove the whole front panel to access the blower housing and the chute going to the lint filter. Clean as needed. (common problem).
3. If everything checks clean, then the thermostat that is mounted on top of the heating element canister is the most common problem but is only one of the thermostats.
Maytag uses a lot of air versus heat for drying. That is why it is important that part of the system is correct.
Mar 14, 2010 | Maytag Dryers
Not drying properly, no heat
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 06, 2009 | Dryers
GE DNXR47GW1WW Dryer is extremely slow to dry clothes (takes over 2 hours per load). The dryer does heat. Any suggestions?
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective. (if this is a gas dryer, please disregard this statement)***
Jun 16, 2009 | GE Dryers
Dryer not drying due to lack of heat
Check the following text to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
3. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Jun 11, 2009 | Whirlpool GEW9250 Electric Dryer
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
Jun 03, 2009 | Kenmore Dryers
Not heating properly, many cycles to dry loads
1. Venting
2. Thermostat
3. Heating element
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Tumble dry is heating but takes forever to dry
check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
