Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
When I press normal wash it lights up but no other buttons respon
When I press normal, light, or any other of the wash buttons, it lights up and 'heated dry' lights up but no other buttons will respond after that, including the 'start' and 'cancel' buttons. I have tried the "console reset" but nothing happened.
  • Whirlpool Master
  • 909 Answers
No repreave there, your board must sadly be replaced.
Posted on Sep 24, 2009
The clean light is blinking and no other buttons respond. it is a new control pannel that i just put in the only button that respons is the start\restart but it will just beep
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 18, 2011 | GE GLD4600NCS Built-in Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I press the power button on the front and no fans run
Sounds like your power supply is not supplying 12v to the system. Check all your power connectors are seated properly on your motherboard, if so then i'm afraid you need a new power supply.
Mar 26, 2010 | Gateway 500GR PC Desktop
Kitchenaid Dishwasher KUDS24SEWH?
This problem was aparently classified under the LG dishwasher / LDF6810ST section, I don't think this problem got looked at by KitchenAid gurus.
Were the problems resolved?
Sep 24, 2008 | LG LDF6810ST Stainless Steel Built-in...
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher lights blinking
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
212 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
