Question about Dell Studio 15 Laptop
I have windows vista just had a new hard drive installed the data off the old drive has been put onto an hdd caddy how do I load it back onto the new hard drive of my computer, the caddy is a plug in via a usb
  • Jaye Ellen Burke
    Jaye Ellen Burke May 11, 2010
    Does this hdd caddy have a drive letter? If so explore the drive's contents for a familiar file name to help you locate the data.
  • 591 Answers
Plug the hdd caddy into your computer with the new hard drive. Find the caddy in the Computer icon and restore the files back to the new drive.
Posted on Sep 26, 2009
    President:
  • 2,049 Answers
When you insert the usb cable from the caddy into a USB port on your notebook, Vista will automatically recognize it and open a dialog box. Choose to view files and folders.
Open another Window using Explorer and resize it so you can see the contents of your C: drive.
Then simply drag your files and folders from the caddy to the C: drive where you want them.
Remember that transferring program files will NOT help you as many of the files needed to run a program are located in other folders such as yours Windows directory. You will need to reinstall any software you wish to use.
This method is strictly for data transfer, as an example all your pictures, documents, spreadsheets, etc.
Posted on Sep 24, 2009
My daughter has lost her windows login password(vista}
There is software for sale that will remove the password. A bit expensive! Maybe a cheaper option to install a fresh copy of Vista from the recovery partition and restore your backups to the new system as all data will be lost. If you have no backups, purchase a new external hdd, install it in the laptop, put Vista on it and put the old drive in the caddy. You can then copy your data over to the new hdd, or purchase the software to unlock the windows password.
Mar 06, 2014 | Dell Studio 1737 Laptop
Getting data off HDD from Caddy ?
I have had similiar issues using caddies there seems to be many connecting parts that can fail or become old and dirty failing to make contact with the hard drive you could remove the hard drive and check these contacts make sure they are clean and making contact
or
You could just remove the hard drive from the caddy and connect it directly inside your computer as a normal hard drive
or
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
http://www.bing.com/images/search?q=SATA+Power+Splitter&qpvt=SATA+Power+Splitter&FORM=IGRE
Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually
click start click on computer to open you should see this drive
If you dont.
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X
you will need to update/reinstall drivers
right click to reinstall drivers.
If you can see your usb drive but its not working
ports (com&lpt) right click update driver
Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
or get one of these
http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9
NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
Hope this helps.
Nov 23, 2012 | Computers & Internet
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
No boot device available - strike F1 to retry boot, F2 for setup utility after getting the blue screen of death
Your PC is telling you that it cannot recognize your Hard Drive. You need to order a new Hard Drive. They are very cheap. Then you will need to re-install Windows. All of your data may be lost, but you can bring your Hard Drive to a data recovery center or PC Store to see if the data can be retrieved.
Hard Drive is probably dead so you will need to purchase a new one.
Sorry and Good Luck.
Oct 15, 2009 | Dell Dimension 8400 PC Desktop
I want to pull info off a hard drive & put onto a disc.
If your new computer doesn't accommodate the drive then you will need a three and a half inch hard drive enclosure to put the hard dive in from the other computer.
You will have to look at the drive to work out which type enclosure you will need.
It will either be a SATA connection like this >>>>
Or a IDE/ATA connection like this >>>>
If you compare the connections on these examples you will one has plastic connections and one has brass pin connections.
As soon as you know which type of drive you have you can then proceed to purchase an enclosure.
When you have got the correct enclosure all you have to do is install the drive and connect it your new computer.
You will be able to access the drive, copy your data and use the drive as an external hard drive.
Regards.
Sep 22, 2009 | Dell Dimension E310 PC Desktop
My WD250 MyPassport external HDD powers on and makes the booting sound all right. It lights up but windows XP never detects it. It used to work prefectly okay before. Any advice.
As you did not specify 2.5" or 3.5" I will give you both sets of steps:
If it is a full sized hard drive and requires power, it may not be getting enough power, have the AC adapter tested at a computer shop. If it is dead/dying replace it, if not move onto the next step.
Try a new usb cable, also available at most computer shops. If the new cable works at the shop try your old cable as well. If the old one doesn't work, buy the new cable, problem solved if it does work the problem is either in the caddy or your computer.
Assuming it's in the caddy, now have the people at the shop swap the HDD from your shell into a new one and test the drive again, as with the above if it works you're done. If it doesn't the problem is internal to the actual HDD. Time to buy a new external drive and send the old one for recovery if it has any crucial data on it.
Let me know how you make out and if needed I will provide additional steps. Also if you need data recovery help let me know your region and city and I will recommend an appropriate facility.
Chris
Jun 02, 2009 | Western Digital Passport® WDXMS1600 160 GB...
Windows Failed to load because Kernel file is missing
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
May 17, 2009 | Dell Inspiron 1521 Notebook
I try to reformatt my windows vista 64, with my cd's it tells me my ntldr is missing im not sure if anyone messed with my settings are whats wrong can u down load a ntldr vista from the net?are is there a...
Do you want to completely restart from fresh with your Laptop, or are you trying to keep the files intact.
If you do not care about the files on the PC then you should be able to put the disk in the drive. Restart the PC and follow the prompts from the Vista installer. If you do not care about the data on the hard drive then when you get to the select a partition you can delete the current partition that has been set up and then format it for your new install.
If you do care about the data on the hard drive then i recommend that you create a back up of the hard drive onto an external HDD or a DVD then follow the steps above.
Hope this helps you out. :)
Mar 17, 2009 | Dell Computers & Internet
WindowsXP not loading after installing Windows Vista Demo Version
You need to get rid of the Vista Demo, and reload xp. You need to keep one or the other I think, you can't keep both operating systems on the same drive. What were you thinking?
Did you install the vista demo as a dual boot setup? Doesn't sound like it.
I hope someone can help you, I can't.
Nov 24, 2008 | Microsoft Windows Vista Ultimate Edition
Hard drive dont load up properly
your hard drive is dead mate. sorry. they die form time to time.
buy yourself a new hard drive and an external hard drive caddy (a 3.5" one) make sure the caddy is the right connection for your old hard drive. either sata or ide.
then put the new hard drive into your pc to take the place of your old one, and load windows onto it.
next get your old hard drive into the usb haddy drive caddy/enclosure, connect it all up and see if you can use the ghost function on norton anti-virus secruity to bring back your old data.
hope this helps.
kev
Oct 02, 2008 | Acer Aspire T310 PC Desktop
Dell Studio 15 Laptop Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
