FixYa.com
Tags:
RCA Remote Control
RCA Universal Remote Control Code (by 3 users)
posted by handydandy on Dec 16, 2007
What is the code number to control Sony standard (tube) tv?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ckeken, posted on Apr 29, 2008
I have an RCA Universal remote control and I want to program it to an JVC television.
Comment by Guest, posted on Feb 03, 2008
codes for a rca remote for a tv 13 inch phipps
Best Solution
posted on Dec 16, 2007
Helpful (85)
Gigatech
Rank:Guru Guru
Rating: 87%, 312 votes
sony code is 002
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 26, 2008
Thanks for Trying (70)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Have RCA remote control with a magnavox tv need code to use.
Can you Help with these Remote Controls problems?
RCA (244889) Remote Control
remote wont program
my new r53np remotes led light... Answer This...
help!!!
i have a sanyo tv, and a rca... Answer This...
need code for universal remote
need code for a hitachi tv for... Answer This...
cfdj,.l
luhb,jhbbtt ikmugf Answer This...
vcr
unable to activate remote... Answer This...
Repair Service
Find Remote Control Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
