Question about Dell Latitude D600 Notebook
Backup to an external hard drive without a floppy drive
Can you help me with this problem. i backup my hard drive of my dell laptop to an external hard drive and it has an error message at the end of it that says "the asr diskette was not created. you will not be able to restore an asr backup without the system information stored on this diskette. please refer to online help for further assistance." Can i use a CD drive in place of a disc drive and if so how do i let my computer know this change?
  • 556 Answers
I believe you would prefer a DVD as the article I referenced earlier said a CD was too small (I made the same mistake before I reread it). It would seem that whatever drive letter the DVD example E:\ is would be used in the name of the file like the example E:\jan30-03.bkf and when the application was complete insert a DVD in the drive and tell windows to burn the content.
Posted on Dec 16, 2007
When doing the diag. test what does code 0146 mean.
Hello, Betty.
That Dell error code indicates that the hard drive is failing. If you are experiencing errors in use of your computer, the hard drive is probably causing your problems.
I'd suggest to back up all your important files from that drive to an external drive or online backup.
Then, replace the drive.
Hope this helps.
Oct 13, 2011 | Dell Latitude E5400 Laptop
Dell 1525 dont maneger is dosent see in the screen how i reformat
Reformatting the hard drive of a computer is sometimes an unavoidable task. Whether you're an IT professional or a private user, there are times when the hard drive has to be totally wiped. These reasons range from reallocating a computer to another user, selling it or donating it, installing a larger internal hard drive or even just to eradicate some flaky behavior. Unless the computer is ancient, reformatting a Dell laptop is a moderately easy process.
1. reformat-dell-laptop-1.1-800x800.jpg Damaged hard drive is a reason to reformat
Back up any data on the PC that you plan on saving. This can be accomplished by using burnable CDs or DVDs, attaching an external hard drive, using an online backup process or hooking up to the corporate backup server.
  • 2 reformat-dell-laptop-1.2-800x800.jpg Older flavors of Windows include a bootable floppy Set the boot order on the laptop. This tells the computer the order that it looks for a bootable disc. The default is the C: drive, but this can be changed by holding down the Delete key while booting the computer. If you're using a floppy, which is common with early versions of Windows, select the A: drive. If you're using the CD or DVD, then select that drive (usually the D: drive) by using the up and down arrow keys. Save your preference and exit.
  • 3 reformat-dell-laptop-1.3-800x800.jpg A software restore CD Insert the media (floppy or CD/DVD) into the computer, and then reboot. Select reformat and install, which will erase all the data on the drive and install a fresh copy of Windows.
  • 4 reformat-dell-laptop-1.4-800x800.jpg 2.5-inch internal hard drive Keep an eye on the process, as earlier versions of Windows often require manual intervention such as selecting options, or pressing the Enter key at certain times. More recent versions of Windows are typically autorun.
  • 5 reformat-dell-laptop-1.5-800x800.jpg Disk image utility Follow the prompts during the installation and after rebooting it. Use the restore CD to install any additional drivers and utilities. Run the Windows updates, and if you're planning on keeping the computer (or assigning it to another user), then install any necessary applications and data files, and configure the preferences, email and printers.
  • I hope you find it very helpful. Thank you for using fixya.
    Aug 15, 2011 | Dell Inspiron 1525 Laptop
    Dell Internal / External USB Floppy Drive 1.44Mb *NEW* is this suitable to use as a external floppy disk drive for Dell Dimension C521 computer
    Any USB external Floppy drive will work with any computer with a USB port, but if you have Windows 98 you will need an USB driver.
    Jul 29, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
    How do I transfer my laptop hard drive to an external hard drive?
    Go to start and click on accesories then under system tools or in the acsesories panel you will se something that says systemp backup or backup, click that then follow the steps to do a TOTAL BACKUP to the letter of your drive. My recomendation to you is to make a folder on your external hard drive to store the backup.
    Jan 27, 2009 | Maxtor Hard Drive
    Software purchase
    Hello dazz_hammer,
    You can put up to Windows XP. If do, I would suggest to add memory and bigger hard drive.
    Or if the pc has Windows Product Key Tag, and what ever the operating system it indicates then you can re-install that operating system.
    Hope this helps and good luck.
    Jul 27, 2008 | Dell Latitude CPX Notebook
    New hard drive(s) in Dell4500s
    You would have to contact dell for the OS disk.
    I dont think you can install the hard disk in place of floppy drive. An external Hard disk would be a better option.
    May 04, 2008 | Dell Dimension 4500S PC Desktop
    Restoring backup files
    well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
    Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
    Hard drive backup
    This seems to be a good article on ASR backup and how to eliminate your error message.
    See Link
    Dec 16, 2007 | Dell Latitude D600 Notebook
    Hard drive backup to an external hard drive
    This seems to be a good article on ASR backup1.gif and how to eliminate your error message2.gif.
    See Link
    Dell Latitude D600 Notebook Logo
    62 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
