Question about Roper FGP300 Gas Kitchen Range
Pilot lights go out often, cant raise cook top
Can it be raised??? How?
3 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: Burners on top will not light with the pilot lights
To Clean:
IMPORTANT:
Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
Posted on May 27, 2009
venexcsd
  • 1185 Answers
SOURCE: need to raise pilot flame hugher on burners
Need to check your gas pressure or use a very fine piece of welding wire to clean out the jets
Posted on Sep 28, 2009
How do i re ignite the pilot light
Hi
The surface on this range have standing pilots that must be lit initially. To light them:
1. Be sure the surface burner control knobs are in the "OFF" position.
2. Remove the grates and cook top.
3. Locate the pilot ports and light each of them with a match. Replace the cook top and grates.
Light the oven burner pilot in the following manner:
1. Be sure the oven control knob is in the "OFF" position.
2. Remove the broiler carriage.
3. Hold a lighted match at the top forward section of the pilot (See diagram). No adjustment is required.
4. Replace the broiler carriage.
Hope this helps...
Daniel
Aug 28, 2010 | Magic Chef 31000 Gas Kitchen Range
How do you raise the smooth cooktop on a frigidaire range?
the cook top is screwed down with several different screws it does not just lift up.what is the reason you want to raise it up.
Jan 24, 2010 | Frigidaire FEF376 Electric Kitchen Range
SF 3000 EWWO how to light pilot
You can raise the top lid of the stove to light the pilot lights for the top burners.
The oven is controlled by a electric glowbar ignitor.
Make sure the cord is plugged into a electrical outlet.
If it is and the oven does not work the glowbar ignitor must be replaced.
Jan 16, 2010 | Ovens
Things do not seem to cook on top in the oven
you might try raising the shelf to the next higher position in the oven. sometimes if the rack is too low things will not cook properly on top. let me know
Dec 17, 2009 | Whirlpool GS460 Gas Kitchen Range
Need to raise pilot flame hugher on burners
Sep 28, 2009 | Kitchen Ranges
To Clean:
IMPORTANT:
or rust removers.
May 27, 2009 | Roper FGP300 Gas Kitchen Range
OVEN PILOT WENT OUT
hopefully the gas smell isn't too strong and posing a hazard to you. If it is, reach behind the range and turn the valve until it is across the gas line and not parallel to it. You should be able to raise the top of the range from the front and see all the workings underneath. There you will find the pilot light.
Feb 14, 2009 | Tappan 24 in. Freestanding Gas Range...
Whirlpool 465 Gas Stove conversion from propane to gas?
I HAVE A NATURAL GAS RANGE AND OT APPEARS TO HAVE ED-F3- ON IT AND IT IS LOCKED HOW DO I OPEN IT
Feb 08, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Pilot light
Ok the OVEN pilot light is located in the broiler part of the over (at the bottom) If you open the broiler and get a flashlight you will see the pilot light unit for the over at the rear on the top. What a cheap piece of **** these Galaxy ovens are.
Nov 21, 2007 | Sears 61301 Gas Kitchen Range
Kenmore Gas Oven/Stove
the pilot light is under your surface top.Raise surface top and relight.It will be in between both burners.
Oct 26, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Roper FGP300 Gas Kitchen Range Logo
35 people viewed this question
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
