Question about Hitachi DZ-HS300A DVD Camcorder
Cant open up cassette
When I turn my camera on, I get disc access then I try to eject the disc but nothing happens it just shuts off. Help
  • cmjensen Feb 28, 2008
    I am having the same problem - screen reads "Disc Access" but nothing happens. The disc drive will not open, but I hear a click when I push the button - like it should have opened but didnt.
    I have the dial set on the video camera icon, not the still camera option...
    any other tips?
There are positions on the rotary switch that determine whether you're on the hard-drive or the mini-DVD functions. There's even a small switch (to the lower left of the rotary dial) that keeps you from accidentally switching to the DVD functions.
Make sure you're dial is all the way to the left and reads "DVD". Once you're set on that, the disc eject button should work.
Posted on Dec 21, 2007
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Aug 10, 2010 | Video Cameras
Probelm ejecting the dvd from my Hitachi GX3100A
If you go to the Hitachi website, you can download the product manual for your camcorder there.
These are the instructions for opening the dvd door.
1 Press down the DISC EJECT button once and
release it.
A few moments after the ACCESS/PC
indicator blinks, the cover of disc insertion
block will open.
2 Gently open the cover by hand fully until it
stops.
This is the link for the owners manual search: http://www.hitachionlinestore.com/survey/manualsearch.aspx
Hope this helps.
Apr 29, 2009 | Hitachi DZ-GX3100A DVD Camcorder
Cann't eject cassette from Canon ZR60
I had a similar problem last few days with my ZR60.
The problem I had was that the tape won't eject and on repeated attempts to eject it would eject as if it had a mind of its own.
I was messing with it a little bit and realized that the door was not opening fully. Being a delicate item I didn't realize that I was not fully opening the door may be because there was a little friction in the pivot pins or what ever.
Try to gently swing the door open fully and see if it helps.
Since I discovered this problem I tried 10-12 times, and every time it would eject the tape and load it.
I was almost going to give up this camcorder last night thank GOD, I am able to use it.
Good Luck to you.
Dec 27, 2008 | Canon ZR60 Mini DV Digital Camcorder
Canon ZR900 cassette won't eject
you could hit like the method for if a canon won't let you put in a cassette but i don't know if that will work. just hit it on the non screen side a few times and in theory it should work.
if nothing it will get rid of stress
Dec 12, 2008 | Canon ZR900 Mini DV Camcorder
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Camcorder Canon ZR 200
First if you have a very bad tape (miniDV) (hard to turn by your hand) the camera will automatically eject coz it cant load the tape to it. it is not a head problem. It seems that you have a mechanical loading issue here. But try to put new miniDV tape. ANd post here what happen. PS Dont use compress gas to clean it you might put new problem. Please use only the head cleaner tape (MiniDV) if you want to clean the head. Hope this may help you
Aug 13, 2007 | Canon ZR200 Mini DV Digital Camcorder
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Hitachi DZ-HS300A DVD Camcorder Logo
150 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
