Question about Garmin nuvi 250 GPS Receiver
When i plug in my Garmin 250 in the car it will not function until i unplug it everything else works great but will not work when plugged in the car
  • 491 Answers
Do you have a factory Garmin cord?
Do you have voltage at the plug in the car?
Is the cord you are using good?
Does the cord you are using have a fuse in it?
Is it good?
Sounds like you are not getting power to the unit when plugged in.
Check all above.
and.......try another cord....try plugging into another cars plug.
Posted on Sep 24, 2009
Where do I find the release mechanism to raise the blade height
UNPLUG THE SAW
Take some time to determine every function and how each one works.
PRACTICE EACH FUNCTION WITH THE SAW UNPLUGGED UNTIL YOU ARE CONFIDENT THAT YOU KNOW WHAT YOU ARE DOING.
Then, plug the saw in and
PRACTICE,
slowly and carefully on easily handled material.
DANGER - THESE MACHINES CAN HURT YOU!
If you don't know exactly how everything works
DON'T EVEN PLUG IT IN.
Aug 26, 2015 | Dewalt Saws
How do i fix my PS3 when I cant see anything, but the system itself looks to be functioning?
You are going to have to do a video reset. Witch takes the video settings of the system back to default. To do this, make sure you have everything hooked up. Power, HDMI. Then, turn the system on, push and hold the power button until the system turns off, then push and hold power button until you hear 2 "beeps" then the video settings will be refreshed. ^^
Jul 14, 2014 | Sony Playstation 3 (PS3) Console
My Garmin Nuvi 250, when plugged into cigarette lighter, switched from a working screen to a non functional screen that has picture that looks like a computer tower with cord or a usb cord or something...
New , later maps for the Garmin take up more space that what unit has in available memory - so you have to get an sd memory card to put in the slot when you do the update.
Jun 12, 2017 | Garmin nuvi 250W GPS Receiver
Garmin Nuvi 250 - When I attach the 12 volt charger lead to my Garmin Nuvi 250 it thinks that it is in USB Mass Storage Mode. I can use the Garmin 250 okay when it is not plugged in. This has just...
The problem is with the socket at the back of the satnav where you plug in the mini USB plug of the power cord. As the socket wears it feels as if the plug is in fully when it's not. Push the plug in further and the problem should be solved.
Sep 24, 2010 | Garmin nuvi 250W GPS Receiver
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
Not turning on
My unit was totally dead. I just kept it plugged into my computer for about 12 hours. I downloaded the newest software from Garmin. When I unplugged it from my computer, the battery seemed to drain quick, but once I plugged it into the card adapter in the car... everything seems to be running great now.
Oct 09, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Problem when receiver is plugged in to charge.
Are you using the charger that came with the unit? If you do not use the one that came with it, the unit may be reading this as though it were plugged into the computer. It will charge then, but will not operate unless unplugged - just as you are describing.
Aug 12, 2008 | Garmin Nuvi 660 GPS Receiver
Missing the letter S
I called Garmin customer service and they told me to plug the unit into my computer and it would reset itself and all the letters would be restored. I did this and it worked! I realize the usb cable does not come with the Garmin nuvi 250, however you may have a cable that came with a cell phone or a digital camera. My camera cable worked great.
Feb 03, 2008 | Garmin Quest GPS Receiver
Garmin nuvi 250 GPS Receiver Logo
175 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
