Question about Hitachi DZ-HS300A DVD Camcorder
CAMCORDER GR-DVL167EK IAM HAVING PROBLEM TO GET THE MINI DV CASSETTE COMPARTMENT TO OPEN. UNIT IN SAFEGUARD MODE REMOVE AND REATTACHED BATTERY. I HAVE FOLLOWED ALL INSTRUCTION BUT NO JOY I too cannot get my disk out of the camera. After charging the battery completly, when I turn the camera on it just says disc access, then it will beep and go blank. What can I do, it hasn't even been a year that I've had this camera.
    Sergeant:
    Champion:
  • 231 Answers
Check and see if camera has a reset switch..more likely switch will be where LCD screen is oposite side..hard to tell what happened..also check and see if camera has a lithium back up battery ..if it does remove for about 10 sec..and retry,,sometimes if moisture get into mechanism.a 'safemode" will happen..
Posted on Dec 16, 2007
I have a JVC mini DV digital Video camera model No. GR-D295U that was lost for almost 5 years and we found it. The camera had a tape inside and we can see it but the sound like jumps, is anyway that I can...
The battery is very likely BAD (has high internal resistance)! Can you take the battery OUT, and run with ONLY the charge cable attached? Does that make any difference in performance?
May 11, 2017 | JVC GR-D295U Mini DV Digital Camcorder
The cassette holder wont come up aoutomatically
what you have to do is ejecting the tape, and as soon as it starts to eject , close the door immediately, then safeguard mode should be gone, and you will be able to eject normally.
Mar 04, 2008 | JVC GR-D290 Mini DV Digital Camcorder
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Cant record, cant open the cassette
The error E01 refers to loading motor problem. The camera will have to be taken to a JVC agent for repair.
Sep 19, 2007 | JVC GR-D250 Mini DV Digital Camcorder
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Hitachi DZ-HS300A DVD Camcorder Logo
59 people viewed this question
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
