Question about Philips HDRW720 DVD Recorder
Hi, why i can not burn a dvd 8x? 4x and 16x no problem what i am duing wrong? please answer
    Scholar:
  • 108 Answers
It depends on the media you are using and also the settings the burning software is set to. besidesd...burning at the slowest speed always...always...no..i said ALWAYS gives the BEST encode wanted.
Posted on Sep 24, 2009
(CRX230ED) CD-RW Burner will it burn dvds?
Read/Write Speed CD-R Write:
4X, 8X, 12X, 16X CLV
24X ~ 40X P-CAV
52X CAV (turbo mode) max.
CD-RW Write:
4X, 8X, 10X, 12X CLV
16X ~ 24X CAV max.
CD Read:
52X max.
Buffer Memory
2 MB
Random Access Time
100 ms.
Interface
ATAPI/EIDE
Sustained Transfer Rate (CD-R/RW Discs)
600 kB/s (4X CD-R/RW read/write)
1,200 kB/s (8X CD-R/RW read/write)
1,800 kB/s (12X CD-R/RW read/write)
7,800 kB/s (52X CD-R/RW read/write)
Media and Modes Supported
CD-R, CD-RW,
CD-ROM (Mode 1 & Mode 2),
CD-ROM XA (form 1 & form 2),
CD Audio,
Video CD,
CD Extra,
Multi-Session,
Packet Writing
Burst Transfer Rate
PIO Mode 4: 16.7 MB/s,
Ultra DMA Mode 2: 33.3 MB/s.
no you will need dvd rw to burn dvd's
hope it helps
Dec 03, 2011 | Sony (CRX230ED) CD-RW Burner
How much burn speed should kept when i burn a cd or dvd like 16x or 8x or 4x etc
Hi ,
The slowest is always the best one !
Less errors , best quality .
Regards .
Jan 09, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
I only can write with 4x maximum while dvd could
DVD burners will only write to the maximum stated.
Also if you are using 4x DVDs then that is all they will burn at without often giving errors when used.
Trying to burn a 4x DVD at lets say 16x can cause burn failure or data corruption.
Cd's on the other hand can burn at lower speeds than they are stated.
To burn DVDs at higher speeds your burner needs to be capable of that speed
Sep 06, 2009 | NEC ND-2500A DVD±RW Burner
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Hl-dt-st dvdram gsa-t20n ata burn speed for cdr changes to 10x minimum automatic soon as i put a blank cdr in. i need to do slower burn Speed (4x) and i tried with different software and its always the...
Your drive doesn't support slower burning speeds unfortuately, here are the specifications for it:
Write Speed DVD+R 2.4x CLV, 4x ZCLV, 8x CAV DVD-R 2x CLV, 4x ZCLV, 8x CAV DVD+RW 2.4x, 3.3x CLV, 4x ZCLV, 8x ZCLV
(8x Speed disc: 3.3x CLV, 8x ZCLV)
DVD-RW 1x, 2x CLV, 4x, 6x ZCLV DVD-RAM 2x, 3x ZCLV, 5x PCAV(Ver.2.2) (16x Media: Not support) CD-R 10x CLV, 16x, 24x ZCLV CD-RW 4x, 10x CLV, 16x ZCLV
(High Speed: 10x CLV, Ultra Speed: 16x ZCLV, Ultra Speed plus: 16x ZCLV)
DVD+R DL 2.4x CLV, 4x ZCLV, 6x ZCLV DVD-R DL 2x CLV, 4x ZCLV, 6x ZCLV Read Speed DVD-R/RW/ROM 8x/8x/8x max. DVD-R DL 6x max. DVD-RAM (Ver.1.0/2.2) (Ver.1.0) 2x
(Ver.2.2) 2x, 3x, 5x
DVD-Video(CSS Compliant Disc) 4x max. (Single/Dual layer) DVD+R/+RW 8x/8x max. DVD+R DL 6x max. CD-R/RW/ROM 24x/24x/24x max. CD-DA (DAE) 24x max. Sustained Transfer Rate DVD-ROM 11.08 Mbytes/s (8x) max. CD-ROM 3,600 kB/s (24x) max.
Jan 28, 2009 | Computers & Internet
Compatibility wth DVD and burning speed 4x instead of 8x
The write speed of your machine is 4x. It will only write at 4x no matter how fast your DVD blank is. When your write at a slower speed, you get a better quality DVD picture.
Jan 22, 2009 | Pioneer Computers & Internet
Acer Aspire 6920 web cam problem
Yes it wil record/burn a video.It had a DVD burner on it.
-Write - 16X/8X CD-R, 10X/4X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-RW, 4X DVD+RW, 5X DVD-RAM, 4X/2.4X DVD+R DL (double-layer), 4X/2X DVD-R DL (double-layer)
Here are the technicial Specifications on the ACER webpage:
http://us.acer.com/public/page9.do?sp=page4&dau34.oid=37461&UserCtxParam=0&GroupCtxParam=0&dctx1=25&CountryISOCtxParam=US&LanguageISOCtxParam=en&c
Jan 14, 2009 | Acer Computers & Internet
Recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Jan 11, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
Cannot write cds at lower speed like 8x
  1. Try to Use Nero or Easy CD creator software for better output.....
  2. Try burning Verbatim 16x DVD+R at 16x first and then burn another of the same type at 8x. And then compare the results. Most times, burning 16x-rated DVD+R/-R media at 12x or 8x will result in fewer PIEs/PIFs.
Whether 1x is better than 8x is another issue. Personally, I prefer 8x speed for most media I use these days (rated at between 4x to 16x but mostly 8x.)
Nov 26, 2007 | Computers & Internet
Philips HDRW720 DVD Recorder Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
