Question about Fellowes Powershred SB-87Cs Shredder
Schreder will not shut off automaticly.
I was told to check for paper around the eye or switch.
I did & it was clean, if that switch is bad how do you
get in there to change it.
Thanks,Dale
  • tchumbleys2 Sep 29, 2009
    I tried air & it did'nt help, I'll just have
    to do it manually.
    Thank you, Dale
    President:
  • 3,085 Answers
Try blowing some canned air down into the feed slot. No spare parts are available.
Posted on Sep 25, 2009
Infoguard sx100m
I don't own this shredder, but most are built with similarities. Usually there is a micro-switch that's used to detect a piece of paper being inserted. Should this switch get jambed, it will continue to "sense" paper being inserted and continue to run.
As I said, I don't know this shredder, but it would be reasonable to assume that someone will need to open the shredder and clean (or replace) the switch.
As a possibility, I think I would try using one of those 3M Dust Remover can's of compressed air and see it you can dislodge any paper or paper dust around the switch by blowing through the paper entry opening. (Will need to look into the opening to see where the switch is located. Usually near the center.)
Otherwise need to have a technician come out.
Aug 28, 2014 | Industrial Paper Shredders Office...
Unit no longer shuts off when on "Auto" setting. I have to use this switch manually to turn unit on and off for every use, and would like to restore original functionality.
Don't know what kind of shredder is is but most have one or two eyes or switches that tell the shredder to start and also tell is to stop. these eyes get paper dust on them and will not shut off
, or they could be bad eyes or switches. Use can air and blow down in center of shredder gears and see if it solves problem. Also shredders shuld be lubricated with shredder oil every now and then....
Sep 20, 2013 | Staples Executive EPS711X Shredder
2003 toyota matrix with code po420
You don't check O2 Sensors when cold,
they won't be operating or switching until
the computer goes into closed loop & converter
lights off at 600 degrees & continues to hopefully
around 900 to 1,100 degrees
Other than replacing a sensor, the only real
test I found of any value, is to watch switching
times on an oscilloscope
You can, as you said, look at scan tool data
Giving your vehicle is a 2003 & converters last
12 to 14 years, you know yours is worn out,doesn't
matter what the inspection gas results were & with
any codes, you should have been rejected & not tested
If you check fuel trim,you will see how well the MAF Sensor
is doing & you can't adjust fuel if the converter is not capable
of holding oxygen for the sensors to read
The front O2's get replaced on all vehicles at 100,000
when or before they slow down & fail
Jul 09, 2013 | Cars & Trucks
Paper jam 202.33 Check rear door. I have checked and no paper jam.
the printer has either a switch with a little lever or an electronic sensor with like a little eye, some were around that rear door. its in the paper path. it makes sure the paper moves through this area OK. I've had the little arm get stuck closed or the little eye needing cleaning. ( a buildup of paper dust makes it think there's a piece of paper there ) clean and or fix sticking lever.
Also, don't let a that little piece of paper fool You. all it needs is the switch/sensor see it. ( tricked Me more than once. ) If You have had a paper jam just before the error, ( that's pretty much Your clue! )
Sometimes just cycling the power will correct the problem.
If all of this does not help, You may have a bad switch/sensor or circuit board. if that's the case, buying a new printer will be cheaper than the service call. ( if You have one of the personal printer's, NOT commercial)
Hope this helps, Ricky L
Jan 23, 2012 | Dell 5310n Laser Printer
The shredder will not automatically shut off. After you have finished feeding the documents to be shreeded the machine contunues to run and you must manuall shut it off.
depending on what you have available, either a damp paper towel or alcohol wipe, or compressed air will work to clean the sensor eye located top at the center of the paper feed opening, you should see a little dot wipe, or spray these out well, then turn the machine off and back on again.
built up dust from the paper causes the sensor to keep registering that there is paper coming in hence it won't stop on its own.
Apr 05, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
I have a Royal VF1000MX Shredder that will no longer shut off automatically.
Easiest try is to clean the "eyes" where you put the paper in....they may just be dusty/dirty,,,,if that dosnt work you may need parts...contact Royal at 1-800-524-0799 for assistance.
Nov 06, 2010 | Royal VF1000MX Shredder
Switcheson fine but does not accept paper
Does it run in reverse???? Does the motor work.???
If it runs in reverse then the motor is probaly OK....does your machine have "eyes" that automatically start the shredder when the paper is inserted??? if it does then they may be "dirty/dusty"...try cleaning them ; if that dosn't fix it then you may have defective "eyes" or defective pcb.
May 10, 2010 | Office Equipment & Supplies
Auto Shut off doesn't work anymore
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Either of these should be located in the center of the paper throat.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Dec 20, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Won't shut off after shredding.
I FIXED MINE!!! Hey folks same problem AS1018CD would not shut off. CURE: Take apart and clean electronic eye. PROCEDURE: 1. Unplug. 2.  Remove shredder and turn upside down. 3. Remove 6 phillips head screws on back of unit ( 1 is under sticker in middle peel back sticker to access screw. 4. Carefully separate unit. 5. Pull off shredder piece. It is a snug rubber grommet fit and just lifts off( gears everything comes off as one piece. 6. Electric Eye is exposed remove screw holding in and gently slide out and wipe clean. Do both sides. While apart clear all debris and wipe entire unit as clean as you can. Put gear assembly back on grommets. Put top and bottom back together. Replace screws. Plug in. FIXED :-)
Sep 14, 2007 | Aurora Electronics AS1018CD Shredder
Fellowes Powershred SB-87Cs Shredder Logo
111 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
