Question about Acer TravelMate 212T Notebook
VERY SLOW ,WHAT SHOULD I LOOK AT. - Acer TravelMate 212T Notebook
  • 3,153 Answers
Some computers can be slow or short of hard drive space for quite simple reasons.
Windows and other program hide temporary files in lots of different places
The best option is not always a program or utility and if you want to do as much as you can for FREE like I do then you have a few options.
1. First you need to be in windows explorer.
2. Click TOOLS and FOLDER OPTIONS
3. Now click the VIEW tab
4. Tick the Show Hidden Files And Folders option
Unpick Hide Protected Operating System Files (it may warn you but you can ignore it)
5. Click APPLY then OK
6. NOTE some files may not delete this is OK Also DO NOT DELETE the folder itself where mentioned for cleaning.
7. Using windows explorer go into the WINDOWS folder and look for a directory called TEMP (it is possible there may be more than one)
8. Select all the contents and delete them. Do the same for any other temp folder e.g. temp000
9. Now navigate to Documents and Settings
There are quite a few folders in here that can be cleaned up
10. Look for folders named "Local Settings" In there you will find more TEMP folders that can be cleaned out
11. Now look inside the Temporary Internet Files. Delete anything EXCEPT cookies. Otherwise passwords for some sites you have stored may need you to type the password again.
12. Do this for each user / profile you see.
13. Now check the C: drive itself and see if there are any Temp folders and clean those out too
To prevent accidental deletion of any files windows needs you should go back to step (4) and change the two settings back to their original
Posted on Sep 24, 2009
    Guru:
  • 174 Answers
It is either you increase the virtual memory or you increase the RAM of the system by adding a more higher RAM to the one on your laptop. To increase the virtual memory, right click on My Computer, the select and click on properties to bring out the system properties, Go to Advanced, then under performance property, click on settings, to bring out the performance options window, then go to advanced, Under Virtual Memory property click on change to increase the memory. But it is always advisable to add an additional memory. You can also do the disk cleanup and defragmentation for your laptop, so as to remove junks and unused files that are making your system to be slow. Thanks
    President:
  • 1,653 Answers
Check that you have sufficient disk space available. The rule of thumb is that the HD should have at least 10 - 20% space left to operate efficiently.
It is a good idea to scan the whole system for viruses, malware and spyware as these can slow down performance significantly. Next scan the system for un necessary drivers and applications etc. You can do this by using a free 30 day evaluation of Ashampoo from www.ashampoo.de that will check out the whole system and assist in removing all the unwanted junk, I have been using this software for many years with great success in my workshop in improving system performance. Also then do a full HD defragment - also available in the Ashampoo tool.
This should speed things up considerably.
Also you can add more RAM to the system if there is any capacity left as this will stop the system having to swap data and use the HD based swap file which is much slower than using RAM to do it.
  • 360 Answers
Start up! I recommend going to Cnet and download Advance System Care. Once installed it has Admin Option go to Start Up and click all the stuff you don't need running at start up.
  • Richard Klein
    Richard Klein Sep 24, 2009
    Just think if you tried all of these solutions. Your computer would be pretty clean and fast. Nice job guys! One thing, if your solutions are correct, then start up would more likely be a problem too. But the shampoo solution kind of catches all.
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Hola, I'm looking for a replacement ceramic insert/bowl for my slow cooker. its broken. Is there anywhere that i can buy another one for a cheap price?
Yes, lots of those available.
Slow Cooker Replacement Parts ' Crock-Pot
www.crock-pot.com/parts/
  1. Cached
  2. Similar
Replacement Lid - Crock-Pot® 5-Quart Round Slow Cooker. ... Replacement Stoneware - Crock-Pot® 5-Quart Round Slow Cooker - Black. ... Replacement Stoneware - Crock-Pot® 7-Quart Oval Slow Cooker - White.
Where can I find a replacement ceramic insert for the GE slow ...
https://ca.answers.yahoo.com/question/index?qid...
  1. Cached
  2. Similar
Nov 8, 2012 - I have looked on GE's site and it seems they only offer replacement parts for major appliances. If someone knows where I could get a ceramic ... Where can I purchase a replacement lid for a GE slow cooker ... 24 Aug 2014 Anyone know how to locate a replacement insert for a slow cooker ... 9 May 2009 I need replacement glass lid for GE slow cooker (6.5 qt). Already ... 7 May 2008 Where would I find Replacement parts for a Slow Cooker? ' Yahoo ... 16 Jul 2007 More results from ca.answers.yahoo.com
GE Slow Cooker ' eBay
www.ebay.com/bhp/ge-slow-cooker
  1. Cached
  2. Similar
GE 3 - Crock Round Slow Cooker 103734 1.5 Quart Inserts. $34.99. Buy It Now. or Best Offer ... It has 3 temp settings. Also your able to remove the ceramic.
GE 6-Quart Digital Slow Cooker - Walmart.com
www.walmart.com/ip/GE-6-Quart-Digital-Slow-Cooker/12442589
  1. Cached
  2. Similar
Rating: 4 - ‎200 votes Buy GE 6-Quart Digital Slow Cooker at Walmart.com. ... to be sent back if under warranty. I would think you could contact GE parts on-line to find a replacement insert to purchase. .... To me, "stoneware" is like ceramic or porcelain. The insert for ...
Customer Reviews: Ge 6-quart Digital Slow Cooker
www.amazon.com/Ge-6-quart-Digital-Slow-Cooker/.../B007P60E94
  1. Cached
  2. Similar
I will never use anything but a ceramic slow cooker again, and never a G.E. ... I am keeping the unit and on the hunt for a stoneware/ceramic liner replacement.
Mar 28, 2016 | GE small appliance slow cookers 106724...
The handle to the lid melted. My fault, I tried to use the insert and lid in the oven. Is it possible to buy a replacement?
Melted my Crock Pot lid handle : slowcooking - Reddit
https://www.reddit.com/.../slowcooking/.../melted_my_crock_pot_...
RedditJul 23, 2015 - So I melted the Crock Pot lid handle.... I....it.... it all happened so fast. Then I messaged Crock Pot to see if they would mercifully send me a...
I have A proline slow cooker, unfortunetly the handle melted ...
www.fixya.com/support/t10606247-proline_slow_cooker_unfortunetly
Oct 3, 2011 - Question about Crock Pots & Slow Cookers. Open Question ... slow cooker, unfortunetly the handle melted last night and came off the lid. can I ...
Shop slow cooker replacement parts from Crock-Pot. Make sure your slow cooker is functioning ... Replacement Lid - Crock-Pot® 5-Quart Round Slow Cooker.
Crock-Pot® 4-Quart Oval Slow Cooker Replacement Lid ...
www.crock-pot.com/lids/...lid---crock-pot...slow-cooker/129960-000-00...
Feb 08, 2016 | Crock Pots & Slow Cookers
I need a manual for how to use
    Instruction Manuals at Crock-Pot.com.
    www.crock-pot.com/service.../instruction-manuals/instruction-manuals.ht...
    Browse our Instruction Manuals to find answers to common questions about Crock-Pot® products. Click here to view on our FAQs now.‎4 Quart -7 Quart Slow Cookers - ‎3.5 Quart Slow Cookers - ‎Specialty
    Manual Slow Cooker - Crock-Pot®
    www.crock-pot.com/service.../instruction-manuals/...slow-cookers/manu...
    Search. Home : Service & Support : Product Support : Instruction Manuals : 4 Quart -7 Quart Slow Cookers : Manual Slow Cooker. Your browser's Javascript ...
    Back to Basics: How to Use a Slow Cooker - The Kitchn
    www.thekitchn.com/back-to-basics-how...
    Apartment Therapy's The KitchnApr 21, 2010 - Prepare the Recipe - A good many slow-cooker recipes require only some basic prep .... Check out this website's post for easy instructions.
Jan 04, 2016 | Crock Pots & Slow Cookers
I am confused is the russell hobbs slow cooker a slow cooker or is it a pressure cooker i am looking for a pressure cooker not a slow cooker
Russel Hobbs makes both a slow cooker and a pressure cooker - confusingly in Europe they call Slow Cookers pressure cookers. The only way to really tel is if there is a special lid with valves and locks (pressure cooker) not a glass or plain lid (slow cooker).
Sep 05, 2011 | Russell Hobbs RHNPC800P 8-Quart Slow...
PC SLOW BOOT UP-SLOW OPENING WORD DOC-SLOW E-MAIL RETRIEVAL-SLOW-SLOW-SLOW. WHAT SHOULD I BUY OR DO?
There are a number of issues might be affecting your PC's performance, some are dangerous while others not that serious.
Learn why is your PC running slow and how to speed it up easily from: http://www.whyismypcsoslow.net/
Good luck to your PC!
Jul 04, 2010 | Computers & Internet
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
I can't set my slow cooker to high
If the slow cooker will not change the display from 0 to 1 to 2 to 3 etc. when you press the "COOK TIME" button, then unplug the slow cooker. Hold both the COOK TIME and the ON/OFF buttons down and plug the slow cooker into the wall. Keep both buttons held in for a count of 10 then release them. The slow cooker should work correctly now.
Dec 30, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
Acer TravelMate 212T Notebook Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
