Question about Toshiba TP50G50 50" Rear Projection Television
No picture i tried to replace the speakers on my toshiba, but while installing the speaker i was distracted and didn't put the ground wire on first and i think i blew out my picture tube. when i power on the tv the light just blinks and the screen doesn't come on. this has never happened before. where would i find a picture tube for model tp50h60. please help. if it is a fuse or if it has anything to do with the motherboard let me know how to fix that. Thanks
    Novelist:
    Champion:
  • 211 Answers
I doubt you blew the picture tube. I do think you damaged the main board ( power supply board). First I would suggest you check the fuses, in both the main board and also the convergence board ( there are two main boards in your set ). Before you start, always use caution by unplugging the set from the wall. To check the fuses, remove the bottom panel cover in the back of the set by removing the screws. Use a flashlight and observe all the fuses you can find and see if any are opened or burned out. ( if the fuse is burned out, it will be black, you may not be able to see if the fuse is just opened without using a continuity checker ( volt ohm meter ) ). Any fuses you find open or burned out, replace with a like fuse ( voltage and amperage ). The set should work fine if a fuse is the problem. If the set doesn't have a bad fuse or won't work after replacing a bad fuse, then you will probably have to seek professional help. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
Is it possible to watch Toshiba picture frame television with external speakers disconnected from back of television
A filter couldn't hurt. I would also suggest checking the grounding strap. I have also come across neighbors who have installed linear amplifiers on their CB radios which overdrive the signal and cause interference with those around them. Now could these antenna be an amateur radio, or HAM radio, setup? If so, they have different restriction but they aren't supposed to cause local interference either. You can contact the FCC to pursue that further.
Great pictures, by the way. Depending on the age if your set, your setup menu for audio may allow you to change the speaker set up to allow you to disconnect each set of speakers & experiment with the sound quality. You may want to disconnect each pair of wire and blow out any dust/dirt with some compressed air as well as checking for any loose strands of copper wire creating an unintentional ground or short while reinserting the wire back into the connector jack. If that doesn't help, you may want to check the wires going into each speaker and check for dust inside the speaker boxes. You would be amazed at how dust can get into things. Remember, dust has moisture, making it a conductor of electricity. Not much is needed to create interference.
Apr 25, 2017 | Toshiba Televison & Video
Tip
Home Theater Setup - Rear Speakers
When people install their own home theater systems they typically use these small stick-type stands for the rear speakers. This leaves one (or all) rear speaker blasting right into your ear, which is not how the rear speakers should be.
Rear speakers should be mounted two to three feet above ear level or higher, get those speakers off of the stands and onto the walls. The reason for this is that they were intended to add a background effect, they are not meant to distract your from the picture.
If your room (or significant other) does not allow speakers to be mounted up, then move your rears back a bit and aim them towards each other, this will maximize their effect and not distract you from the front while you enjoy your movie.
on Jan 27, 2010 | Audio Players & Recorders
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 25, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
I have a 2007 trailblazer. The rear speakers didn't work and some of the head unit lights didn't work. I replaced the headed unit and that didn't fix it. I then replaced both speakers and one...
Put new wireing in going to both back speakers, Factory wireing is verry thin end it breaks with age. Change it over to at least 16 guage speaker wire or 12 guage, Your system will sound a lot better.
Oct 26, 2012 | Cars & Trucks
1991 toyota carolla seca cs limited head unit wiring colour codes
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
May 25, 2012 | 1991 Toyota Corolla
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
I am replacing a very old Toshiba cassette/radio and it has only one wire (+) going to the speakers. How does that work? I am trying to install another radio that doesn't work this way.
Hello sir, hi most likely the one wire is the live audio out, you are missing the ground line, the missing wire maybe connected to ground already, just like in car wiring where the other line is the body. if not check your speaker connections, they should have a "+" and a "-" sign terminal. to complete a speaker connection it should have two terminals. No speaker would work with only 1 terminal.
Oct 05, 2010 | Toshiba Sony XRCA350X
I get interference on car radio from my hd headlights
you will have to try changing the ground location for the lights, and keep the ground wire as short as possible... if the noise still happens after trying different ground locations, then you might have to pull the radio and put a ground loop isolator on the radio... that installs easily and you can pick them up at any auto parts or radio installing shop... hope this helps ya
Jun 10, 2009 | Sony Xplod 240 Watt 6" x 9" 4-Way Speaker...
Only a steady pulse comes out of my bull power
hello, it seems that you may have a bad ground on your amp? turn everything off(pull amp fuse at battery) and go to the amp ground and clean paint away to bare metal! secure ground tight and make sure the car battery is not low voltage! this may stop the pulse! the sound problem of no sound in speakers, if still there! make sure the speakers are not shorts or pinched to ground! this could damage the amp! hope this helps, good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Jun 12, 2017 | Magnat Bull Power Reflex 300 Car Subwoofer
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
Televison & Video Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
