Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
Pc and monitor turn on, monitor goes off after few seconds
I can get a picture with any other monitor, but when this monitor is plugged in 4 seconds then off. Please help! thanks
    New Friend:
Please don't get advise from India, this model has a known "Inverter" problem. Order a new one on ebay, and replace it... Problem solved!!
Posted on Feb 10, 2010
SOURCE:
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
My viewsonic vx924(vs10162) start very good when i turn on my pc then after 2 or 3 seconds goes white but i turn it off and on again and it works just fine i try it with other pc and does the same what can...
The picture board on your monitor is bad, since the power led or button is on and all connection are correct and goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jul 04, 2010 | ViewSonic VX922 19" Monitor Flat Panel
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Screen cutting out
Take care.
Jun 29, 2010 | Hannspree HH251H 25" LCD Monitor
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
Monitor goes dark
If the power light turns yellow, there is no signal being received by the monitor from your computer's graphics card. The screen will shut off (go into idle mode), which is a low-power state, that saves energy. Check that the cable on the back of your computer is plugged into the right graphics card (many PCs come with more than one, these days). There may be one built into the computer's mainboard, and another one may be on a separate graphics card located somewhere else on the machine. Only one of these will work on startup. If one doesn't work, try the other.
Apr 23, 2010 | Dell E176FP 17" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
177 people viewed this question
Ekse
Clive
Clive
