Question about Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw
What are the setting on the 136 chainsaw
What are the setting on the husqvarna136 chainsaw H=? L=? how many turns ?
Start at 1.5 turns from bottom on both and then adjust it once you have it running
Posted on Sep 24, 2009
Testimonial: "great thanks work first go"
Hto remove crankshaft seals on a husqvarna 136 chainsaw
You will fully disassemble the engine as you must the cylinder from the crankcase. Husqvarna only sells the seals with the bearings they must be pressed on to the bearings. Since the 136 uses the same bearing set as the 141 you can order a set seals for the 141. In this the old seals must be pressed off first.
Here is a link to a site that sales the 141 seals.
Husqvarna oil seals set fits 36 136 141 142
Dec 21, 2014 | Husqvarna Garden
Set timing on husky 136
The timing is set by the key way in the cranck and the key in the flywheel, you cannot adjust the timing, you can alter the air gap between the ignition module and the flywheel magnets, the gap should be 0.3mm, the key in the flywheel is cast into the flywheel and cannot be replaced.
Feb 14, 2013 | Garden
New coil being fitted on husqvarna 136 forgot gap seting
The air gap should be set at 0.3mm.
Regards.
Mar 10, 2011 | Husqvarna Garden
I have a husqvarna model 136 chainsaw that wont start.Has spark,gas compression
trie with another spark plug if not heling check maybe air leak between cilinder and carb. also if not helpin rebuild carburattor.
Dec 03, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Settings for low and high speed screws for carb for husqvarna 136
turn them both in , gently, till they bottom out and then back them out 1 1/2 turns. This will get you real close and then fine tune them from there. hope this helps.
Sep 10, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Replacing the oil pump on a Husky 136/142 chainsaw. have you any manuals or can you tell me how to do it thanks john
Go to husqvarna.com then united states then homeowners then chain saws then manuals and parts then type in model no.
Apr 06, 2009 | Husqvarna Garden
Husqvarna 136 chain saw
Hi
high speed H=3/4 turn
low speed L=1 1/4 turn
iddle speed adjust accordingly
best regards savumihai71
Jan 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Dec 14, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw Logo
161 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
